FINALLY! CUSTOM APK INSTALLS (NA MODEL)
Micah
Toms River, NJ
Absolutely still can't get my HU to show up on my computer. I have a MacBook Pro with the stupid USB-C ports. I have a USB-A to USB-A cable and a USB-A to USB-C converter and can't get it to show up in ADB devices in terminal on Mac or to be recognized by VMWare Fusion (it doesn't even show up as something I can connect to the virtual machine in the USB devices available). Any thoughts?
Use boot camp and not VMWare Fuwion. Huge difference in USB peripheral support. I own a Macbook Pro and it is a pain in the ass for flashing with Hondata. Have to repeatedly unplug and replug the connection to get a solid connection to the flashpro over USB. The first time it seriously pissed me off. Now I am used to it. I have a Dell 7567 which works perfectly without popping in and out the USB connector. But that PC is dedicated to gaming and cryptocurrency wallets, plus it is twice as thick as the MacBook.
eL_pIt
Pedro
Mwxico
Civic Turbo Plus 2017
now i combind file but on "did" , "eir" file no have ODBII data. What problem would it be if I did not enter data into the file? I do not dare to risk it.
Would you make it works?
Please share with me the solution, beacuse I pair the OBDII to an android device then copy the folder in to the head unit, but does´t work, right now I have the proble that the head unit doesn`t pair a n smartphone any more.
please help
simon_lefisch
2020 Civic Si Coupe
I have a MBP running Windows on Fusion and it works perfect. No probs flashing ktuner or pushing apk's via adb. USB support is perfect.
mikealanni
US
2016 Civic EX
please help
I think deleted the folder that you copied will return everything to normal
himynameisaaron
Aaron
PA
2018 Pearl White Honda Civic SI Coupe
Installed Honda Hack earlier. Installed fine, got Waze working and everything. Question is, am I able to download and install any app that would run on any other Android device? For instance, I downloaded Viper EQ but it fails to install. Am I missing a step? Do I need to install something else prior?
This may be lazy on my part, not really interested in reading 30 pages to find the answer.
tuxmonkey
R-00330
Houston, TX
'17 Civic Type R #330, '17 Jeep GC Overland
I would also like to know this. I would like to be able to run Sound Cloud off the screen because there currently isn't an AA app for it. There is one for Waze.
ElusiveJones
Bob
RI, USA
2016 Civic Coupe EX-L
Has anyone had any luck downloading spotify songs/playlists to a usb and having them stay? I have a limited data plan on mobile and would like to download the "extreme" quality songs for my playlists while on wifi and be able to listen to them on the go, like I can with my phone's Spotify app and micro SD card(s7 edge). It works fine when I download them to usb while on my home wifi for the one rider, but once I restart the car everything is lost and I have to do it all over again. I have the pro auto hack version. I've been hesitant to mess around too much with the deeper settings as I'm not *super* tech savvy. Write access is enabled also. My usb has more than enough room to hold my play lists. Any help greatly appreciated!
Edit: Also, am I missing something? I thought one of the biggest reasons to root the HU with Auto Hack was to get rid of the ridiculous "safety" restrictions. Honestly, these restrictions are LESS safe. You have people pulling off to the side of the road just to read a two second text on the HU(but billboards with multiple sentences and half naked ladies is fine). And if you don't have auto hack, scrolling through a Spotify playlist 10 songs at a time, playing a song you dont want to hear, re-pressing the browse button, scroll ten more songs, rinse and repeat for 5 minutes. All of this RATHER than fast swiping down and tapping a song in a matter of seconds.
Sorry for the rant, but what am I missing to disable the factory "safety" settings? It's not the parking brake bypass - I honestly don't even know what that does. Any help? I'm not getting any responses over on XDA.
BTW I'm on a '16 civic coupe ex-l running android 4.2.2
ElusiveJones
Bob
RI, USA
You need to find the apk version of any app that was made for Android 4.2.2. Installing current APKs will not work.
edwanny
Jacksonville fl
Scion
Ok - just rooted mine and installed some stuff (netflix, newpipe (youtube), plex and chrome). It was pretty easy (I just used a macbook pro) if you are technical at all.
Honestly - if you aren't technical I'd advise following the command line instructions; way easier to do it that way. Pushing apks via ADB and installing them in the shell (pm install) is pretty easy.
Tips: I ended up just doing an "adb reboot" each time I modified the whitelist. Note that things will be a little weird when you come back up from an "adb reboot". Don't worry about it, everything goes back to normal once you do a full reboot (by holding the power button down). Here are the versions of each app that worked for me.
Chrome - https://www.apkmirror.com/apk/googl...browser-60-0-3112-107-2-android-apk-download/
Netflix - https://www.apkmirror.com/apk/netfl...lix-3-16-0-build-5294-9-android-apk-download/
Plex - https://www.apkmirror.com/apk/plex-...release/plex-6-3-2-1332-android-apk-download/
NewPipe (this is youtube, but WAY easier to get working than the youtube app - use this if you want youtube) - https://f-droid.org/repo/org.schabi.newpipe_37.apk
I've included the whitelist file that will make these 4 apps works (and it disables all the regulations for the built in apps).
Code:
<?xml version="1.0" encoding="utf-8"?>
<whiteList>
    <formatVersion>1.0</formatVersion>
    <contentVersion>1.1</contentVersion>
    <applicationLists>
        <application>
            <property>
                <name>Clock</name>
                <package>com.android.deskclock</package>
                <versionCode>1-999999999</versionCode>
                <keyStoreLists>
                    <keyStore>null</keyStore>
                </keyStoreLists>
            </property>
            <controlData>
                <withAudio>without</withAudio>
                <audioStreamType>null</audioStreamType>
                <regulation>null</regulation>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Browser</name>
                <package>com.android.browser</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <withAudio>with</withAudio>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Calendar</name>
                <package>com.android.calendar</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>People</name>
                <package>com.android.contacts</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Gallery</name>
                <package>com.android.gallery3d</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Search</name>
                <package>com.android.quicksearchbox</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Music</name>
                <package>com.android.music</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Settings</name>
                <package>com.android.settings</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Downloads_Ui</name>
                <package>com.android.providers.downloads.ui</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Downloads</name>
                <package>com.android.providers.downloads</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Calculator</name>
                <package>com.android.calculator2</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Cert Installer</name>
                <package>com.android.certinstaller</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Package Installer</name>
                <package>com.android.packageinstaller</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>LiveWallpaperPicker</name>
                <package>com.android.wallpaper.livepicker</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>ApplistUpdate</name>
                <package>com.honda.displayaudio.whitelist</package>
                <keyStoreLists>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Navigation</name>
                <package>com.honda.displayaudio.navi</package>
                <keyStoreLists>
                    <keyStore>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</keyStore>
                    <keyStore>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</keyStore>
                    <keyStore>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</keyStore>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>yes</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>TelematicsApp</name>
                <package>com.honda.telematics.core</package>
                <keyStoreLists>
                    <keyStore>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</keyStore>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Aha</name>
                <package>com.aha.android.app</package>
                <keyStoreLists>
                    <keyStore>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</keyStore>
                </keyStoreLists>
            </property>
            <controlData>
            </controlData>
        </application>
        <application>
            <property>
                <name>Updater</name>
                <package>com.honda.appupdater</package>
                <keyStoreLists>
                    <keyStore>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</keyStore>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Chrome</name>
                <package>com.android.chrome</package>
                <keyStoreLists>
                    <keyStore>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</keyStore>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Netflix</name>
                <package>com.netflix.mediaclient</package>
                <keyStoreLists>
                    <keyStore>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</keyStore>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>Plex</name>
                <package>com.plexapp.android</package>
                <keyStoreLists>
                    <keyStore>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</keyStore>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
        <application>
            <property>
                <name>NewPipe</name>
                <package>org.schabi.newpipe</package>
                <keyStoreLists>
                    <keyStore>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</keyStore>
                </keyStoreLists>
            </property>
            <controlData>
                <revert>no</revert>
            </controlData>
        </application>
    </applicationLists>
</whiteList>
How do I do this? Do I just go on the browser on my car and download Netflix for example? Sorry I’m not following what needs to be done here... just need a few more instructions
Mikeybc
Northern Ontario
2017 Civic Coupe EX-T, 2015 Nissan Murano
Netflixx is included in the latest version of hondahack. I had the old free version and didn't have any Netflix or Waze etc. So I just updated hondahack through the settings tab and all the apps such as Netflix, Waze, Google Maps, Sygic are now there.
edwanny
Jacksonville fl
Scion
Hey Guys, I don't have much time today but though I should share. I found a way to instlal custom apks. I will post a tutorial this Monday.
I'm sorry for the wait, but I have a long trip this weekend!
Update: Thank @codeage for making an easy to follow guide over at XDA :).
https://forum.xda-developers.com/android/general/guide-how-to-enter-developer-mode-2017-t3621582
Do you think that you can download and unzip unto a flash drive and then connect that flash drive to the headunit?
ElusiveJones
Bob
RI, USA
Has anyone beaten the eq-fix "all:default" the SIs and ex-Ls are getting in order to flatten DSP? Our models seem to be stuck in shitty sound mode
