RickDick
- Eric
- Jan 26, 2018
- 0
- 15
- 5
- St-Constant
- Honda CIVIC SI 2017 Sedan
After changing both damper mounting base, both damper cap and both bump stop, the problem is still present. So I left my car at Honda to check thoroughly with a steelman tool to listen if the noise came from suspension. Finally after the test that confirmed that the noise came from the rear suspension, Honda still phoned Honda Techline and the Tech told him that honda was aware of the problem because I was not the first that it happens even after changing part. It ordered to stop his investigation because even if it changes the suspension or the damper mounting base, the noise will come back immediately in cold weather. So as long as he will not create a replacement part to fix the problem, I will have to live with and wait for the reminder or a new service bulletin.
It is not dangerous for safety but very noying to hear on a new car.
My wife has a civic EXT 2016 and no noise come with the rear suspension, it's only on civic SI with adjustable damper.
I would say that everyone who has the same problem as us should go to Honda to work on finding a solution.
