CivicTypeRsenal
- #16
Does anyone know the stock wheel/tire weight?
That's right, my apologies guys. Offset is already measured from the center of the wheel, so if you get a wider wheel with the same offset, half of the width will go to each side of the centerline. You will need to stick with +60 offset wheels to keep the stock feel.The AHA/VSA/ABS systems were designed to the tire center line, i.e., rims with ET60 offset. Changing rim diameter or width doesn't change ET offset (unlike backspacing). Thus, if you're never going to engage those systems, or are going to turn them off, then run whatever offset that you want (that fits). If you are going to rely on those systems, then I would recommend not changing offset by a lot, especially as the CTR does not appear to have a negative roll radius up front.
Herein lies the problem. I want 9.5" wide at 19", but can only find ones I like at +42. Short of customizing the wheel, which is already $530'ish each.You will need to stick with +60 offset wheels to keep the stock feel.
You'll be fine with that offset.Herein lies the problem. I want 9.5" wide at 19", but can only find ones I like at +45. Short of customizing the wheel, which is already $530'ish each.
You're still good. I'm going low 30s at the same width.Sorry, correction +42
You think so with low ET30s? I remember seeing this on Facebook for 9.5" ET35 and giving me doubt on that type of setup...do you have word otherwise?You're still good. I'm going low 30s at the same width.
Any word from Rays regarding CTR specific wheels, or have you ditched that project?@youCTR i have test fitted the wheel size that I'm buying. No rub issues with a 265/35 tire
I don't ditch projects....Any word from Rays regarding CTR specific wheels, or have you ditched that project?
Dope. Will it be available to us regular folks, or is it a one-off just for you? hahaI don't ditch projects....
I haven't said anything because I haven't gotten the go ahead to post information about it. I will say that wheels have been ordered and are being manufactured at Rays Japan.
A few sets have been ordered for the first run, but it will be available for all!Dope. Will it be available to us regular folks, or is it a one-off just for you? haha
Music to my ears. Thank you, sir!!!A few sets have been ordered for the first run, but it will be available for all!
I'll try to post info soon.
