Center console arm rest removal
My2016Civic
Cumming, GA
2016 Civic EX w/Sensing - Modern Steel Metallic / Gray
Just curious, have you priced having the console and side pieces covered at a local upholstery shop? I know we have several in my city that would do it.. Since you already know how it comes apart you may be able to get it done cheap
I went ahead and ordered the center console pieces (all 3) from http://hondapartsnetwork.com. Not all that expensive like the door armrests are.
SoonerinFL
BOOMER!
St. Augustine
2016 Honda Civic EX-T and 2016 Acura TLX Base
About $1500 to $2000 around my neck of the woods
P4Cruiser
Salt Lake City, UT
2019 Honda Civic Type R Sonic Gray, 2018 Honda Accord EX-l 2.0 Turbo, 2010 Toyota FJ Cruiser, 1965 GMC Pickup, 2009 KTM Enduro 690R
CivicLX2016
NJ/PA
2016 Civic
I picked up the three leather console pieces from junkyard for $160 shipped.
P4Cruiser
Salt Lake City, UT
You should have grabbed the door armrests too.
CivicLX2016
NJ/PA
2016 Civic
It's pretty expensive. One door panel is $120 and the other is $150.
Probably better to wrap those yourself. Honestly, My elbows rarely touch the door armrests anyway.
P4Cruiser
Salt Lake City, UT
Yeah? You have part numbers for these $19 pieces? I can't find them.
83504-TGG-A61ZA
Right Front Door *NH900L* Armrest Assy 19.42
83554-TGG-A61ZA
Left Front Door *NH900L* Armrest Assy 19.42
83704-TGG-A71ZB
Right Rear Door *NH900L* Armrest Assy 15.24
83754-TGG-A71ZB
Left Rear Door *NH900L* Armrest Assy 15.24
This is for the 2017 Civic Hatchback EX with Leather. The Sedan and Coupe prices are much higher. Don't know why. I'll let you know when they get here if they are the correct ones.
CivicLX2016
NJ/PA
2016 Civic
83504-TGG-A61ZA
83554-TGG-A61ZA
83704-TGG-A71ZB
83754-TGG-A71ZB
So it's possible they wouldn't fit in a sedan or coupe. Hmm
cmanman
Parker
Looking good there @My2016Civic. The OEM leather center consoles pieces are so well worth it. I think yours looks better than mine.:thumbsup: It's a shade or two lighter than the Hobby Lobby faux leather, but I think it works well since it plays off the carbon fiber strip in the middle of the seats. Then I also did a Homelink with dark gray then the lighter gray to play off that carbon fiber look (The real real reason - when I went shopping eBay did not have any homelink in light gray for under $50. I made an offer for $40 and the seller accepted:headbang:) That center piece is like $100 and you get the entire assembly, which I only used the leather top cover. I would stick with your original plan first to see if you like it. If you don't you can always order the center piece later. I just took a pic with the center and armrest. You can judge.
@SoonerinFL where did you find the Homelink? Do you have a link? I can't not find on eBay....
CivicLX2016
NJ/PA
2016 Civic
I just replaced the center console arm rest and the center left and right armrest with leather from http://hondapartsnetwork.com. The center armrest can be easily remove by lifting up at the front or back of the piece. The center console you have to buy the assembly and remove the two screws that holding the center armrest to the assembly. It took me about 5 minutes to do the three pieces.
Parts #
Right Console Armrest Assembly 86411-TBA-A11ZA $39.03
Left Console Armrest Assembly 83416-TBA-A11ZA $39.03
Armrest Assembly 83441-TBA-A01ZA $98.73
I was thinking about doing the door panel armrest too, but there were way too much for what i think they are worth ($170 to $150 each). I was not going to spend $600 for leather armrest door panels. So I went to Hobby Lobby, used a 50% coupon for black leatherette/vinyl and did it myself (yard of material $4.00 and gorilla glue $3.00). It took some time to cut the pattern out 4 times and get it fit tightly to the armrest but it looks okay. If I would do it again, I would use the remain leathertte/vinyl for the center console. It's alot cheaper that spending $98. LOL
Can you tell me where these two screws are for the center leather console install?
P4Cruiser
Salt Lake City, UT
Open the center console and slide the armrest forward. Underneath on the front are 2 Philips screws. Remove them and gently work the cover off front to back. It takes some effort, but pops off.
CivicLX2016
NJ/PA
2016 Civic
