AlphaDigital
- Alex
- May 21, 2020
- 7
- 2,518
- 3,667
- MW
- civic
Fuel demand is mostly tied to airflow/boost. When we max the turbo out, the fuel pump just so happens to be around its limit too, mostly in the midrange at peak boost/torque. In some cases Type Rs have a crappier fuel pump than others and upgrading it will allow you to see more boost but it’s not a big difference.
Thus, on a stock turbo, more fueling capacity isn’t going to equal more power UNLESS you use a higher quality fuel that also requires more volume such as ethanol.
It also means that upgrading the turbo will also require a better pump.
The cheapest overall option for a decent boost in power is thus an XDI pump with ethanol, unless you want to run $10/gal race gas or go full send with turbo and fuel kit
In the cases where some of the HPFPs are underperforming are you seeing those maxed out before you reach the limit on pump gas? I feel like a lot of CTRs are nearing 100% duty just FBO. In those situations, does upgrading the HPFP allow you to make additional power, even if its just peak?
