kefi
oh shit waddup its dat boi
- Jan 8, 2020
- 14
- 1,614
- 2,523
- Central Florida
- Website
- fk8.clinic
- 2018 Type R
- Build Thread
- Link
XDI-EVO High Pressure Fuel Pump Upgrade
Hi CivicX! I'm proud to bring you Xtreme-DI's high pressure fuel pump upgrade for the 2017+ Civic Type R which is now supported on the OEM ECU with a Hondata FlashPro. It retails for $1599 and is currently the only standalone high pressure fuel pump upgrade that you can run on the OEM ECU. The OEM high pressure fuel pump is the main barrier to making more power and this is the direct bolt-on, drop-in replacement we've been waiting 3 years for. More boost, more ethanol, more power. FK8 Clinic is one of the few currently authorized dealers of this pump.
Purchase here: https://fk8.clinic/collections/performance-parts/products/xtreme-di-evo-high-pressure-fuel-pump
Current lead time is 1 to 2 weeks, not including shipping time, due to the currently high demand. Free shipping is included.
- Supported on the stock ECU by Hondata
- 36% more fueling capacity than the OEM Bosch HPFP
- 12% more fueling capacity than the HPFP in Hondata's Fuel System Upgrade
- Can be used to further upgrade the Hondata Fuel System
- Stronger springs rated for 7800rpm engine speed, versus the OEM 7200rpm. Other parts in your engine will need to be upgraded too.
- Rated for 240 bar / 3500psi, versus Bosch's 200 bars, which is beneficial for fuel atomization and delivery.
- Combined with XDI's 1400 and 1650cc injectors it has been shown to support over 600whp safely. These injectors are not supported on Hondata yet.
Frequently Asked Questions
How difficult is this to install?
It is a simple 1 hour job in your garage. The pump is located right on the top of the engine and only needs a few things removed and taken off. An install video is at the end of this post.
Do I need a custom tune? Are there basemaps?
Yes, you will need to get a custom tune in order to make any power with this pump. There are currently no basemaps available and the current basemaps will simply not use the extra capacity this pump offers. Enabling the mod in Hondata will not give you a boost in power, it will only make the pump function properly. FK8 Clinic offers 25% off all tuning services with the purchase of an EVO pump!
Is this a kit? I.e. low pressure fuel pump, fuel lines, injectors
No. This is only the pump, and at this time there are no other standalone options that are compatible with the OEM ECU that is not part of the Hondata fuel system upgrade other than the in tank low pressure pump. XDI's injectors will hopefully be compatible soon. However, the pump is the main initial restriction to power so for anyone looking for a nice step up that don't want the full Hondata upgrade, this is the solution for you.
Is a code required to enable HPFP control like Hondata's fuel system upgrade?
Yes, but it is included with the purchase of the fuel pump.
Will this benefit me if I don't have a big turbo and I'm on pump gas?
Yes. The benefits are much greater combined with a turbo and/or ethanol, but nonetheless the OEM fuel pump still largely a limitation even on pump gas with a stock turbo. You will need a custom tune to see any benefits either way.
Can I run full E85 with this pump?
Yes, but you may have to sacrifice some potential power, especially with a big turbo. Additionally, the OEM in-tank low pressure fuel pump has been shown to eventually fail due to extremely high concentrations of ethanol wearing away the contacts. If you take this route in order to avoid mixing, it is recommended to also upgrade the in-tank pump.
Can I pass emissions?
The pump itself does not modify anything related to emissions nor does it require the disabling of any emissions related CELs. However, rules vary from location to location.
Install Video
Courtesy of ACCORDing to Joel:
