1. Without a fuel system, not a ton. More peak horsepower than midrange torque. 425hp, maybe closer to 450.@kefi So just curious of a few things, assuming an upgraded turbo like the P600 on 93:
I am just trying to plan this out as best I can. I don't want to find myself at the dyno wishing I would have upgraded a part of the fuel system that I didn't. I want to get it right the first time. Thanks in advance for the help.
- What power can be expected with stock fuel system?
- What power can be expected from just replacing the high pressure pump with the Xtreme-DI EVO?
- At what power level do the stock injectors need to be upgraded?
- At what power level does the stock in tank pump need to be upgraded?
I really appreciate you getting back to me. I actually don’t mind keeping midrange torque down. I am mainly looking for top end, as I am used to the typical Honda power band. So I would be happy at 425-450 whp up top and keeping mid range torque around 375 wtq.1. Without a fuel system, not a ton. More peak horsepower than midrange torque. 425hp, maybe closer to 450.
2. The inverse of the above. Without a turbo, you’ll see great midrange gains but not much at the top end (400-425) UNLESS you’re running ethanol, in which case expect 425-450whp.
3. 500whp or so seems to be the consensus but we still need more data
4. If you’re running E85 it’s a good idea, otherwise not necessary. It’s been shown to handle up to 600whp.
The magic combo is a turbo and fuel system, since you will get both midrange torque gains and peak horsepower gains. You’ll likely land at 475-500whp on ethanol without any additional items, 450-475 on 93.
Yes, once you get a turbo your OEM fuel system will be maxed out across the board (assuming the tuner utilized all of the available pumping capacity).I really appreciate you getting back to me. I actually don’t mind keeping midrange torque down. I am mainly looking for top end, as I am used to the typical Honda power band. So I would be happy at 425-450 whp up top and keeping mid range torque around 375 wtq.
But I guess at those power levels I would be at the peak of what the stock fuel system can do up top. At that point would it be better to get the Xtreme-DI just so the stock pump isn’t running at 100% duty cycle? How bad is it to run a pump at its limit?
How much time do you really spend up top? I've found on the street the mid range is much more fun and used frequently. I think having a tune with reduced mid range torque would be great for a track, but while driving on the street it does leave considerable power on the table.I really appreciate you getting back to me. I actually don’t mind keeping midrange torque down. I am mainly looking for top end, as I am used to the typical Honda power band. So I would be happy at 425-450 whp up top and keeping mid range torque around 375 wtq.
The way I see it is that this car has plenty of midrange power, even with a bigger turbo youre likely making 350+ lbft of torque in the midrange. Having a bigger turbo will just push that powerband further to the right, increasing linear power, and power under the curve.How much time do you really spend up top? I've found on the street the mid range is much more fun and used frequently. I think having a tune with reduced mid range torque would be great for a track, but while driving on the street it does leave considerable power on the table.
Yeah I totally agree. I think first, my biggest concern with keeping the midrange down is longevity. I know these engines aren't weak by any means, but I am definitely trying to avoid breaking anything. Second, I am used to and enjoy the power band of my S2k. The car obviously lacks a ton of midrange, but there is nothing like taking an engine to redline. I have gotten used to working for the power.How much time do you really spend up top? I've found on the street the mid range is much more fun and used frequently. I think having a tune with reduced mid range torque would be great for a track, but while driving on the street it does leave considerable power on the table.
Correct. You’ll need a custom tune. But, if you buy the pump through me the tune is 25% off ?As far a I know there is no actual basemap for this pump which means you will not get much out of it on a basemap. I got a hold of a datalog on e50 basemap using this pump and it reaches 90% duty cycle in some areas of the pull
I ordered from full race on day one after support became available still waiting on it.Correct. You’ll need a custom tune. But, if you buy the pump through me the tune is 25% off ?
That is definitely something I have thought of, when it comes to using the XDI pump with pump gas. I had to reduce mid range boost a ton due to my stock HPFP but I wonder how much is safe for the internals.Yeah I totally agree. I think first, my biggest concern with keeping the midrange down is longevity. I know these engines aren't weak by any means, but I am definitely trying to avoid breaking anything. Second, I am used to and enjoy the power band of my S2k. The car obviously lacks a ton of midrange, but there is nothing like taking an engine to redline. I have gotten used to working for the power.
