Xtreme-DI EVO fuel upgrade discussion
Status
Not open for further replies.
Learn2turn
Christopher
Rio Rancho NM
'79 Toyota Longbed PU, '95 (Drift Toy) Miata, '05 Tuned Gran Prix White S2000, '19 Championship White C-Type R
I wonder if anyone has drilled the line while it remains in place.
Fastrax04
Indio, CA
2017 CTR
Also just to clarify, the Hondata/XDI/Full Race FK8 hit 596/525 back on the Church Automotive Dynapack in Dec 2020 on race gas with the following mods
XDI EVO35 HPFP
Hondata HP Fuel Line
Hondata LPFP
Hondata LP Fuel Line
Hondata Injectors
Full Race G25-660 Turbo Kit
Built Longblock
As of today, its on its 3rd fuel line, which is an OEM line that was modified by XDI. It definitely flows more than the Hondata line. Car should be going back on the dyno soon with some small tweaks.
fk8mike
canada
civic type r
Waiting for @kefi to recover. Pick his brain on best fuel system upgrade to use since likely going w him for tuning.
the best move to do going with your tuner!?and the verdict is??
WhiskeyTango
Matthew
Milwaukee
2019 Civic Type R
XDI EVO35 HPFP
Hondata LPFP
Hondata Injectors
Built Longblock
Church Dyno you say? So subtract what? 40-50 hp?
19typer
Kevin
NY
2019 Civic Type R
car has built engine and turbo, not really the comparison most are going to do
AlphaDigital
Alex
MW
civic
Unless the built block has a drastically different compression ratio or displacement, it really shouldnt matter imo. The only difference is that the internals are stronger to push it. I guess there wasnt mention of any headwork having been done but if there has been ,it wouldnt be a straight apples to apples comparison.
19typer
Kevin
NY
2019 Civic Type R
compression is only part of the equation. 540 plus on a built everything to me isn't that impressive. I want to see the fuel pump make big numbers on a setup the majority of people will have. Anyone can spend a lot of money and make 500 plus.
Hondata
Hondata
Torrance California
www.hondata.com
23' Type R,22' Civic Si,18' Accord 2.0T,17' FK8
Our high pressure line was carefully tested and sized to match our high pressure pump. If the high pressure line is not matched to the pump then the high pressure fuel control does not work correctly, for any pump. Keep that in mind when I see posts about people drilling it out to 'flow more'. There needs to be a restriction in the high pressure line for it to work correctly. It needs to be matched to the pump. Too big and you lose pressure control. Too small is probably better than too big.
AlphaDigital
Alex
MW
civic
It depends on what the equation is trying to evaluate.
If youre looking to test the limits of the turbo without potentially grenading your engine, it makes sense to build the block if you have the means.
Not everyone has the means to buy a new engine if theirs tanks while making big power. Forged internals is insurance against that, you know as well as I do it gives you greater leeway to push the setup.
What are the other parts of the equation that is missing if this is the case?
Forged internals are negligible to the amount of power you make unless your static compression ratio and displacement are different than stock.
If I have two engines and the only difference between them were forged internals and everything else was the same, they should make the same power. Unless im missing something?
Status
