Xtreme-DI EVO fuel upgrade discussion
turbociv910
taylor
wilmington nc
wrong the hondata xdi test car uses a hondata fsu fuel line and injectors along eith intank pump.
No, but ok, you must know more than him. I talk to him every day🙃
Oem line drilled bigger than the previous recommendation and dw300c intank in the progress.
AlphaDigital
Alex
MN
civic
It is beneficial to drill a oem line on a oem pump if youre going to be near maxing it out. XDI users reported drops as much as 20% pump duty by drilling it. You dont "need" it, but has been proven to raise your pump ceiling.
Is it 20% drop after installation or after drilling?
turbociv910
taylor
wilmington nc
drilling.. stock line will still support good amount of power. carlos made 590 on the drilled line and xdi pump/hondata injectors
Jrn450
Jonathan
Killeen Texas
Civic Type R FK8
But you guys know it all!
got this when the XDI support was first released. This is snap of the test car owner’s response. Ok, he is running a drilled line you win jackass
highlander
stefan
nova scotia
2010 civic Si,2017 civic type r
and what fuel was being used?
Jrn450
Jonathan
Killeen Texas
Civic Type R FK8
Update he has a oem drilled line which have not been tuned for it it was drilled by xdi themselves
turbociv910
taylor
wilmington nc
q16 to showcase the maximum power, but he does realize that is a unrealistic fuel for the average user so they're working on getting back to the dyno with pump gas and blended ethanol tunes.. Working with the new rampage maf housing now too. I do not know the duty or how much room they had left to go.
I'm just sharing the information I know to be correct, no need for name calling.
turbociv910
taylor
wilmington nc
I commented to the balladesports that we need fuel line they answered as they are working on it. I think someone will make the fuel line.
a bolt on solution would surly sell i believe
WhiskeyTango
Matthew
Milwaukee
2019 Civic Type R
So he's running the rest of the Hondata kit, without utilizing the fuel line? What f*ing sense does that make? Sus.
highlander
stefan
nova scotia
he’s using all of the Hondata fuel system but swapped out the hpfp with xdi I believe
