Brandons2697
Which kit is it?XenonDepot often has sales on their kits and I got mine for around $84. Really good kit. No issues at all so far.
The same kit you asked about earlier...Which kit is it?
No issues with it...I went with the 35 watt bulbs vs stock 55 watt...here is a view of the ballasts in the engine bayCarlson,
Any issues installing the H11's in your Civic? Any photos under the hood? Looks like a no-brainier upgrade for $50.
Yeah, I will add relays, you need one for each side right? The good thing about the kit is its so easy to put the old in, I can swap back to stock until I do get the relays on....when I wired my fog lights on my old Accord, it just had one relayPlease install relays with HIDs...
Just because it works without one doesn't mean a relay isn't necessary.
One relay is fine for powering both sides.Yeah, I will add relays, you need one for each side right? The good thing about the kit is its so easy to put the old in, I can swap back to stock until I do get the relays on....when I wired my fog lights on my old Accord, it just had one relay
Okay, I was checking this one out, I know I could make my own, but figured if this worked and for low cost, maybe others would jump on board tooOne relay is fine for powering both sides.
That will work perfectly. You can run 35w or 55w ballast with no concern. The draw isn't much different.Okay, I was checking this one out, I know I could make my own, but figured if this worked and for low cost, maybe others would jump on board too
https://www.amazon.com/Relay-Harness-Xenon-HID-Conversion/dp/B00554PR6I/
I am only using 35 watt bulbs, I won't be upgrading those to any higher, so I think this should work out, you think so?
Good description! Worth the cost to add in to avoid problems in the futureThat will work perfectly. You can run 35w or 55w ballast with no concern. The draw isn't much different.
The reason you need a relay is because a normal halogen bulb will draw 8-10 amps. HID draw less once they get running, but when you flip them on there is a very high in-rush of amps. 15-20+ amps sometimes. Your factory wiring is spec'd to handle the amperage of halogen with an acceptable tolerance zone. Companies aren't going to pay for more expensive wiring than is needed. Your HID will turn on and work fine, but you're going to be heating the wiring up every time you turn your lights on and eventually the insulation is going to give out. This is why we use relays.
Nice. You happy with the color and what wattage are the bulbs?I got XD's 4300K Extreme HID kit that already comes with a relay and grounds built into the harness. Well worth it imo.
The Philip's 4300K bulbs throw the light a little further than the 6000K's, which is why I bought them, but they are more yellow than the LED DRL's. So, if you want that upscale look, the 6000K's are more appropriate.
And I do get flashed occasionally because they are so bright. Even turning on the high beams really doesn't outshine them. I live in the middle of nowhere though, so my headlights are my only light source on the road, and I need to watch out for deer. I have been in two collisions with deer, and I'm not too keen on getting in a third!
http://www.xenondepot.com/H11-HID-Kit-Xtreme-HID-p/xt-h11.htmLink to your kit?
