cloudkid
- Cloud
- Aug 25, 2020
- 4
- 17
- 3
- OKC
- 2020 FK8 Boost Blue
Hoping you guys can help me. I've looked over the Winter Wheels super-thread, and countless other posts here, but to no avail can I seem to piece together the information I need mostly. I only want to find a good set of winter rims and tires. This is due to so many variances when it comes to the Wheel & Tire selection process.
For this basis I want to keep my 2020 FK8 Type-R completely stock when it comes to suspension and do not want to have to bend/cut or do anything else to my wheel-wells and fenders. I would like to find some wheels and tires that will fit without modification. The only Mod I will consider is wheel-spacers, which is part of what's confusing me.
1) When it comes to Aspect Ratio, the higher the number, the better for Winter-Driving and the greater amount of tread life, correct? Essentially higher Aspect Ratios = more rubber. What is the maximum aspect ratio one can have if they go with an 18" diameter rim? Could i get away with a AR of 50? Or do i really need to stay as close to the OEM 30 as possible? Does the reduction of wheel diameter make more room for more Aspect Ratio?
2) What is the maximum width that I can get on these rims and tires? 265 seems to be where it maxes out with stock fenders and housing? Is this accurate? Are there any requirements for spacers as long as its under 265mm? If so, how do i best determine the right spacers?
3) Spacers - are spacers dependent on offset or on tire width, or both? Can't seem to find the right answer in this regards.
These are just a few things I'm confused on. Thanks for sharing any insights or information to guide this total newb at buying aftermarket rims?
