Windows constantly fog up on the inside
mikeywk
Mikey
CA
2017 Civic Hatchback Sport 6MT
Is anyone experiencing this problem?
I live in California, so it doesn't get colder than 50-60F in the winter. As the weather gets colder, I've been noticing my 2017 Hatch Sport constantly fogging up way too much on the inside of all windows (front side back).
In the morning all the windows are so fogged up inside that I basically need to have the AC on all the way to work. Then in the evening commute I also need to have the AC on (even if it's just at low), otherwise it starts fogging up constantly. Is this normal or is something up with my car???
mis3
PT
Ontario
Mercedes, 2018 SI Coupe
To the OP, did you turn on Recirculate Air?
mikeywk
Mikey
CA
  • #3
I'll check when I get to my car later. Should I have it on/off?
Lunar
NorCal
2016 Civic Touring Sedan
Using the recirculate function generally adds to fogged up windows in the winter. Keep it off if your intent is to avoid foggy windows.
Rikee
Ottawa
MDX 2012 - Civic 2016 Touring
same problem here. Seems like the car is sealed too much and does not let the moisture out when turned off.
mikeywk
Mikey
CA
  • #6
Okay, I'm glad to hear it's not just me. I look over at my neighbors cars (parked right next to me) when I get in/out of my car and they are not fogged up at all... just mine completely white on the inside.
mno86
Milwaukee, WI
2016 Honda Civic Touring
Additionally, the windows fog up on this car very easily in the sense that I get a hazy film over the windows constantly after a few weeks of cleaning. I personally believe this to be a result of the plastics gassing. I’ve never seen it so intensely on a car before.
canalrun
NY
2017 Civic Sedan Touring
I have the same problem. I'm in New York State so it does get cold here. Several times the windows have fogged up seemingly way more than they should have, this morning for example. I turn the air conditioning on, temperature up, fan to high, and make certain that Recirculate is Off.
This seems to be an ongoing problem in Hondas. I have had other brand cars that don't fog up like this.
Our first Honda, in the 1970s or so, fogged up so bad on the inside that we actually had an ice scraper that we used to scrape ice/frost off the inside of the side windows. The Civic is not that bad, but Hondas still fog more than they should.
Barry.
  • Like
Reactions: jms
CivicXI
NJ
Civic EX-T, Civic EX HB
Instead of turning the AC on, turn the defroster on. This is effectively air conditioned air being reheated and then blown over your windshield through your dash vents.
Another thing you can do is wipe your windshield with soapy water then wipe dry. The thin film of soap breaks up the surface tension of water and prevents the microscopic droplets from forming (which is what fog is).
tapakidney
Northern VA
2017 ABM Civic Si Coupe
For me, I leave AC and recirculate on by default. When I start to see fog, I turn off recirculate for 3 min, then back on, and I'm good again for a while.
Browncoat3000
Red 5 standing by
Todd
Civic Si, Odyssey EX-L
You can also apply a treatment like Rain-x, or one of the glass cleaner wipes with anti-fog.
I cleaned mine throughly and applied rain-x with a micro-fiber towel last summer. Still keeping the windows clean and fog-free several months down the line, and it's been wicked cold here in the Midwest.
tsupersonic
NY
'17 Civic Hatchback EX-L, '17 Forester XT
Yes, I had the worst fog problems yesterday. In western NY, it went from 60 to 20 with rain then snow. It was foggy as hell, and climate control was a PITA. Every other car was fogged up as well
