Will this setup work? (FK7)
Kmattykinz
Matt
Oregon
2019 Civic Sport Touring
I’m looking to get a flush fitment without rubbing.
planning on running Enkei 18x9.5 +30 on 235/40/18 tires lowered on Eibach Pro Kit with 20 mm spacers in front and 20 mm spacers in back.
Thank you in advance. I’m racking my brain trying to figure this out
Mintmoney15
Alex
Parker colorado
2018 Honda Civic hatchback sport
Might rub a little. Go check out Fitment industry’s gallery to conform what will not rub.
bugboy32337
Tallahassee
2019 Civic Si Coupe (MSM)
30mm offsett with 20mm spacers = 10mm offset
I think this will rub on ANY lowering springs.
Kmattykinz
Kmattykinz
Matt
Oregon
Yeah I started doing more research, and realized my error. I’m new to the wheel thing.
Decided to go w/ 235/40r18 18x9.5 +30 no spacers on Eibach pro.
Wheels are more confusing than the engine stuff in my opinion ?
Derek.
Ottawa, Canada
2019 Civic Sport HB 6MT, 1996 Accord EX 4dr 5MT
At least you're asking before buying. I love when people ask if something will fit, after they already bought it lol
GoldClass
Singapore
Civic Hatchback
I read that you are also looking at wider tyre. 235 will work because is ‘stretched’ on 9.5. But if you are considering 255 or 265 down the road, then you might want to look at +40 or +45.
Vic_L
Victor
British Columbia, Canada
I would definitely go with a +40 ~ +45 offset range to be a little bit more on the safe side.
9.5" will poke past the fenders, a little bit.
I'm running a set of 18x9 +40 Enkei PF07's, paired 245/40/18 tires, this is how it looks:
Front (look back from the front bumper)
Honda Civic 10th gen Will this setup work? (FK7) received_343888419616797
Rear (looking back from the driver door)
Honda Civic 10th gen Will this setup work? (FK7) received_2686419724721092
Mintmoney15
Alex
Parker colorado
Think your missing the pict
Blank_FK7
Long Beach
'17 FK7
I’m on d2 pro springs and I’ve research a lot. ( Check my posts). But my take on it is for an aggressive drop like mine, 18x9.5 +40 wrapped with 255/40 or 245/40 will be good. Although some people say you don’t need to roll the fenders with this fitment, I’d do it if you get passengers like I do despite my ”natural camber” from lowering springs. Also, no spacers needed. Hope that helps!
+1 Checking on https://www.fitmentindustries.com/search-wheel-offset-gallery. Go to gallery and type your specs. There are a lot of info And pics for different setups
