Will it fit? 18x9.5 +38..
MrLETTUCE
Alfonso
Wisconsin
'19 Civic Si, '05 Acura RSX
Hey all, I saw a thread before on this, but it was for a Type R and I have an Si,.
Will a pair of Gram Light 57CRs 18x9.5 +38 fit on Si stock tires with the car being lowered on Eibach prokits?
Thank you guys in advance! :)
jayy_swish
Jay
Are the tires 235/40r18?
If so then yes they max out at 9.5, so they will fit
MrLETTUCE
Alfonso
Wisconsin
Yea those are the stock measurements for the tires. Thank you! Do you by chance know if 245 would fit or is that cutting it close?
jayy_swish
Jay
I’m running 255/35r18 on 18x8.5 so yes you can run bigger. 255/35r18 will fit your set up as well
andrew0809
Andrew
Pico Rivera, CA
2020 Civic Si Sedan
yes they will everyone does these specs! 18x9.5 38+ is a flush fit. You’ll be good on stocks
SCcanyoncrvr
Kev
Orange County
2019 Civic Si Sedan
stock tires will fit but the stretch and wheel gap to fender will look funny and handling will be compromised. Moving up a size is highly recommend (245). With that said if you do move up your clearance is dependent on the type of driving you will see. As long as you are not cornering aggressively (track/canyon) you will clear fine. If you are then slight modification to front fender required.
my experience on this matter comes from 5 sets of wheels and 3 different tire size selections
