Will 18 x 9.5+45 fit on an Si?
fatherpain
Tom
Hello all,
Wondering if 18 x 9.5+45 wheel will fit a 10th gen Si?
Fits the type R perfectly and wondering if it’s the same for an Si?
Please lmk,
Thanks
Tom
fatherpain
fatherpain
Tom
Shoot… the bolt pattern is 5 x 120 I believe. Thank you for the reply
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
19 SPT 17 EX-T 08 LX 21 CRV 12 Acc 14 328I CONV
You can get wheel spacers that go on a 5x114.3 hub and the spacer will have 5x120 studs
arpypat
Civic
Yes, but those are usually ~20mm thick, so the wheel will effectively be a +25 offset on a 9.5 width. Would probably rub at stock height, unless you had 235/40 tires stretched on, fender work, or more negative camber.
MrJustin81
Justin
2019 Civic Si
I run type r wheels on my Si coupe in the summer with 20mm adapters on stock suspension and I’ve had zero issues
arpypat
Civic
Ya, but those are 8.5" wide and +60 offset.
OP was asking about aftermarket 9.5" wide wheels with + 45 offset (but with 5x120 bolt pattern needing a 5x114.3 adapter for the Si.)
fatherpain
fatherpain
Tom
basically I have a set of TE37SL’s (18 x 9.5+45) in a 5x120 bolt pattern, a buddy at work is interested in but he drives an Si and was wondering if it was compatible.
Sounds like maybe with wheel spacers… but then there is the possibility of rubbing…
arpypat
Civic
Depending on how far you guys are willing to go to make this deal work, you could find a wheel shop / machine shop that could redrill the mounting holes to 5x114.3.
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
Roll the fenders.
