Who's running 19's? Post them up.
m_kluch
Maryan
Michigan
2018 Civic Type-R
I’m going to guess 245/35/18,
Let’s see if he notices we switched his regular coffee with Folgers Crystals...
Agreed. Surprised to see people not knowing their own wheel sizes.
Z06Chris
C. Yi
Atlanta, GA
2019 Honda Civic Type-R
You mean 255 wide. Do you know what your camber is at front and rear? Any rubbing?
Sorry, typo. 255/35.
Not sure what my camber is at. Only rub on really bad bumps when not in R mode.
I haul like 300lbs of supplies for my restaurant weekly and drive in R mode to my shop about 10 miles without it rubbing.
type_r_tom
Tom
Fort Walton beach, FL
2017 CBP civic type R 2004 Berlina Black S2000
245/35/19 not 18’s as said they are 19x9.5 +35mm. Currently on 265/35/19 now
m_kluch
Maryan
Michigan
2018 Civic Type-R
They look like 18’s but must just be due to the spoke design. Also the tires looked pretty meaty on them which you dont usually get with 19’s. Surprised they are only 245/35.
Hows the clearance with the 265? Whats your camber specs?
Superfly
D
Central Pa
2018 Civic Type R / 2018 Civic Si Sedan / 2018 Civic Si Coupe / 2018 Acccord 2.0 Touring / 2001 S2000
19x9.5” et40
265/30/19 Michelin PS4S
On Swifts, used to rub in the front but I don’t rub anymore after bending the tabs. Rear never rubbed. Initially pulled the front camber pins but high speed straight line was “nervous”. Put the pins back in and drives perfect.
Honda Civic 10th gen Who's running 19's?  Post them up. 5721D9F1-71E6-45CE-8B81-DAF44BD50BAA
Honda Civic 10th gen Who's running 19's?  Post them up. 04294B43-A271-45BD-9F29-FBA37440E573
Honda Civic 10th gen Who's running 19's?  Post them up. 2EB452A3-D9FA-4D98-9EC5-290B97D8AB23
Honda Civic 10th gen Who's running 19's?  Post them up. 3C516DE1-77A2-40EF-8932-2FBE7491260D
Honda Civic 10th gen Who's running 19's?  Post them up. 1C4674D8-E7DC-4B63-AADE-75E128819928
Honda Civic 10th gen Who's running 19's?  Post them up. DC3C2BFA-50F9-4271-A58A-4F55A6312B04
Honda Civic 10th gen Who's running 19's?  Post them up. 78709381-E409-45BB-8844-D481A81B71F5
type_r_tom
Tom
not sure on camber specs i never bothered to align it after i installed swift springs. the rear i removed the fender flare and did some cutting to make some room. the front i removed the locating pin up top and maxed out the stock adjustment for camber. only mods to the front were bending the tabs flat and trimming some of the fender liner a bit near the side marker light.
RepyT
Almost Stock ‘19 R on 255/35-19”
Dave
Destin, FL
2019 Civic Type R FK8, 2017 Lexus GX460 Luxury
Thanks.
I must admit, thought I was going to see something amazing when I saw 355mm (Almost 14 inch wide tire). Then the let down... 35 meaning 35 percent of width, almost five inch Tall sidewalls, had to be a typo, especially with 19” unless huge lift.
I was hooked and would be in the boat if you’d said 355/20-17.
18TypeR-13922
ADM
Philadelphia
2018 CBP CTR, 2022 MDX A-Spec, 2015 Accord EXL
OZ Ultraleggera HLT 19x8.5 53mm Michelin Pilot Sport AS3 255/35/19
Honda Civic 10th gen Who's running 19's?  Post them up. 2D174F00-34D9-45CB-9237-4ADD43AC74C1
islander670
2017 Civic Hatchback Sport Touring (Sold), 2019 Clarity, 2020 CTR
19x9.5 +36 TE37 ULTRA TRACK EDITION II
Yokohama Advan A/S 355/35
How do you like the Yokohama tires? Just ordered a set to replace the OEM rubber bands. Same width except they’re going to be 35’s.
RepyT
Dave
Destin, FL
well your guess is wrong....so much for being a smart ass.
Make nice Tom, it’s all good innocent fun. At least you called me smart.
