whiteline insert or perrin insert for Si RMM
saiko21
Sai
Sacramento
2019 Civic Si Sedan (Sold) , 2005 Toyota Corolla (Sold)
which insert is better for performance without scarifying comfort or NVH levels in the cabin?
I checked few reviews but it's kind of mixed. can somebody chime in about them
Gandalf
Adam
Georgia
2020 Civic Si Sedan MSM
I know this is not a direct answer to your question but here is my post/2 cents from another thread. honestly from a pure price stand point with their current coupon, I would go with Whiteline, I doubt the materials used can be that much different in stiffness, could be very wrong though:
Installed the Perrin rear motor mount inserts. Bought from Amazon for about $40, MAPerformace was a few cents cheaper and direct from Perrin was more expensive. Figured since I already have an Amazon account might as well go with them and it still came in 2 days even with the pandemic. The Whiteline equivalent can be had cheaply right now ($20 shipped), but I read here, never confirmed though, that the Perrin was a little less harsh (material hardness) so I decided to get it, also their 20% off coupon wasn't active at that time, had it been, I would have been all over it instead. I also like the symmetry of the Perrin as opposed to the Whiteline.
My brother has the Hasport 62A mount in his car, it's not terrible, but it's more than I would like to deal with on the daily. These inserts by comparison are very mild, I can tell it's doing it's job and there is minimal NVH introduced. As other's have stated, it's most noticeable at idle with the A/C on, with it off it's barely noticeable. Anything over 1500 RPM seems to make it all unnoticeable (A/C on or off), at least for me. Only driven it about 5 miles so far, so it may settle in more and be almost completely unnoticeable. I'm happy with it, tried to get it cheaper but couldn't find any better deal.
Honda Civic 10th gen whiteline insert or perrin insert for Si RMM hiDjhPr
Honda Civic 10th gen whiteline insert or perrin insert for Si RMM XNEA740
Honda Civic 10th gen whiteline insert or perrin insert for Si RMM aPkczp0
saiko21
saiko21
Sai
Sacramento
Thanks for the info. I ordered whiteline insert because of their sale coupon and cancelled it the moment I read that whiteline insert is 91A durometer rating which can be harsher compared to perrin. Now I am thinking of sticking with stock for sometime or upgrade to Type R RMM.
saiko21
saiko21
Sai
Sacramento
Yeah perrin is 2halves which needs to be inserted on both sides of RMM whereas whiteline is only one side. comparatively I feel whiteline should transmit less vibrations in cabin
pinhead66
Bay Area, CA
2019 Civic Si Sedan, 2018 Odyssey EX-L
Have a CTR rmm right now which was already a huge improvement over the Si mount. But I feel theres still room for more improvement before it becomes a nuisance NVH wise. So I’m giving the whiteline insert a shot since its on sale and its only one insert vs two.
du ma may
anthony
htown
racezzz
27won rrm put 3k miles and is smooth.
all the inserts stuff is bs.
saiko21
saiko21
Sai
Sacramento
27won is for track I need something which is balanced for performance and daily driving. whiteline is better I guess
du ma may
anthony
htown
racezzz
I dd mine and have no problem. u have to break it in and yes the begging is violent
V3N0M_VZL4
Mauricio
Miami, Florida
2022 Civic SI
any know if this product is compatible for the cvt transmission? if not anyone know any replacement for the CVT version?
saiko21
saiko21
Sai
Sacramento
Not sure but CVT uses a plastic RMM. better to upgrade to Si RMM first
Oddwayne
Nj
19’ Si coupe & 99 ej6
I went with the type r mm with Perrin inserts. Great set up. Very very very little nvh on take off and that’s only if I’m lazy and not giving enough revs. It’s not like having the other mounts on the market that are machined pieces. My current setup keeps the motor in place pretty well for my power output. If you have a 400+ car, than the inserts may be overwhelmed at that point. With that said, with your si mount and Perrin inserts, you’ll be more solid than the type r mount alone.
Tanuktun
Tomball TX
2019 Civic Ex Hatchback
Why is everything plastic!!! I just swapped my plastic endlinks for accord cast ones when I upgraded to the eibach rear sway bar.
Now I'm debating just swapping for the SI rmm or the SI rmm + perrin insert or hasport 62a
lowlife.drew
Andrew
College Park, MD
2019 Honda Civic Si sedan
Just installed the WhiteLine insert on my Si.
Wanted to know if anyone else was experiencing harsh start-ups after installation?
I installed it twice to double check everything was good. Drives pretty sturdy with no real extra vibrations or odd noises
FRDA250.FK7
Vancouver island
2019 Hatchback Sport
Did you ever figure this out?
pinhead66
Bay Area, CA
I finally got around to installing the Whiteline insert with my CTR rmm a few weeks back and I loved the performance improvement in shifting. Felt nice and tight and no delays necessary when doing the 1-2 or 2-3 shift for a smooth experience. But the crazy vibrations with the A/C on during a hotter day was just too much. Took it out and switched over to a Hardrace which has no NVH but isn’t quite the improvement of the insert. I’m interested to see how the upcoming PRL mount works out.
