Whiteline 26mm Solid Rear Sway Bar Kit
JO3L
JO3L
Joel
Southern California
FC1E5, NA6CE
@Sport-injected Glad you enjoy the bar as much as I do everyday on mine. It is indeed very predictable and easy to get the car to rotate. Just use the throttle exactly like it should be.
Vincent@27WON
REDEFINE the Aftermarket
Vincent
Las Vegas, NV
www.27won.com
Just got one for our car. Going to install in the coming weeks and do a review.
Sport-injected
Scott
Central Jersey
www.youtube.com
It made a big difference, you'll love it! And I used the softer setting.
raingsey1
Raingsey
Minnesota
2017 Civic Si Coupe
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
Just wondering if anyone had a chance to use both the Whiteline and RV6 26mm rear sway bar. Looking to get the stiffest set possible. Just bought some D2 coilovers and thinking about putting in the rsb as camber arms/end links are already off. Thanks in advanced!
What spring rates are you using for those D2 coliovers?
raingsey1
Raingsey
Minnesota
2017 Civic Si Coupe
turbociv910
taylor
wilmington nc
i could hardly tell a difference with the 22mm, I didnt know they made this. My warehouse is out of stock atm. will buy one when they are available
CanadiaegeanBlue
Humza
She rotates! Did the Whiteline Springs, 26mm RSB, and Toe Arms all at once. Stepping up from the 22mm Whiteline RSB to the 26mm is quite noticeable, I certainly wouldn't recommend anyone going from stock to this setup with limited performance driving experience.
Car felt great at the AutoX , I definitely need to work on my lines to improve my time but that's all on on me. Just waiting to drop the subframe to do the clutch, and at the same time the Whiteline Anti Lift Kit, and 27mm FSB with End Links go in :)
Honda Civic 10th gen Whiteline 26mm Solid Rear Sway Bar Kit 20200911_000643.JPG
turbociv910
taylor
wilmington nc
She rotates!
do you think the accord end links are better than the ones that come with the whiteline kit? I got my kit finally but have not installed yet
CanadiaegeanBlue
Humza
The Whiteline ones are stress-tested to handle the 26mm RSB, I'm not sure how long the Accord ones will last. The Accord ones are coming off my 22mm RSB, which they were good for with over a year's worth of use
Sport-injected
Scott
Central Jersey
www.youtube.com
No
