JO3L
- Joel
- Apr 17, 2018
- 6
- 387
- 379
- Southern California
- FC1E5, NA6CE
What is it: Part number BHR97XXZ
What is included in the kit: 2 point adjustable 26mm bar, adjustable rear links, bushings, nice billet saddles and the lateral locking clamps to prevent the bar from shifting side to side.
What does it fit: all 2016+ Honda Civics including Type R.
Why would you want this: If you want the stiffest solid rear bar option for the 10th Gens. If you want to eliminate any lingering understeer or even induce some oversteer to get the car to rotate. If you are worried about degrading ride quality through stiff springs but still want to reduce body roll.
(Photo taken from website)
With about 3k miles daily driving, a couple autocross events, and a canyon run I feel like I have enough feedback to share with the community. Most if not all of my driving experience with my Si has been so far been on OEM springs and with the 22mm Whiteline bar installed. I got that Whiteline bar after missing out on getting the Type R bar brand new from Honda back when they were selling for stupidly cheap. I would say with the 22mm bar installed I for sure still experienced understeer on the stock tires. Less so with sticky rubber because of higher slip angle, but it was still present when over driving a corner. In most events I would also need to run about 5psi more air in the rear than the front to induce some extra rotation.
Now with the 26mm rear sway bar installed I can report that virtually all understeer is gone! If I feel the car starting push, a quick lift off the throttle pedal to unload the rear suspension gets the car to rotate before getting back on the throttle and really feel the LSD pull the car through the rest of the corner. I have experienced lift off oversteer aka snap oversteer on other front wheel drive vehicles I upgraded rear bars on and this is very different feeling. It is much more controllable and predictable which is a true testament to how stiff the 10th Gen chassis is compared to Hondas from the early 90s.
While this setup might not be for everyone, it is a very good setup for guys like me who donāt ever plan on upgrading to stiffer aftermarket springs or coilovers. At this point your only option to control body roll is through bigger sway bars. The only bars that I found that is stiffer and as complete of a kit as this one are the Karcepts and RV6 kits. Use your best judgment if you want to install this on a vehicle with stiffer springs than stock. Just a heads up be prepared to 3 wheel on every inclined driveway because this bar is stiff. For those who may be worried, I have thoroughly inspected the rear subframe and sway bar mounting points and donāt see any stress on any of the welds. No noise or squeaks to report of with this kit either so far. Once the grease wears out there might be some noise, but lucky for us it takes maybe 5 mins to pull the bushings off and regrease them.
Stiffness increase % math for those who are curious over stock bar sizes.
Base= 16.5mm solid = 74,120 Stiffness factor --------------516% increase
Si= 18.0mm solid = 104,976 Stiffness factor -----------------335% increase
CTR= 20.5mm solid = 176,610 Stiffness factor -------------158% increase
WL 22mm solid = 234,256 Stiffness factor -------------------95% increase
WL 26mm solid = 456,976 Stiffness factor
