RookieOfTheGear
- Ay Ay Ron
- Nov 12, 2022
- 32
- 351
- 255
- California
- 10th Gen Honda Civic Si (Coupe)
I was picking up some exotic party items from my local drug dealer who just so happens to have a 2019 4dr si and is always getting new mods. I own a 2018 2dr si so we always talk about hoes and bitches and what’s new with each others cars, this particular time he said he just installed the white line rear bar and Honda accord end links 2weeks prior and said it was one of the cheapest and most beneficial handling upgrades he had done. He took me on a ride around the block hitting the turns hard and fast . I knew right away that I had to get my Oxycontin & ecstasy pills and go straight home to search for the price and place my order for the same whiteline and end link setup. The white line was $146 on Amazon and the end links were $70 for the pair at the dealership. The rear bar came with the two new bushing and obviously the rear bar it’s self and the end links just came with the end link only no hardware no nuts or washers but u can reuse the bolts and nuts from the oem end links everything fits perfectly. Removal is easy unscrew the bolts going through the lower control arm n the to bolts holding the bracket to the cars body. wiggle the oem bar out its a tight squeeze but you can get it off with out disassembling anything thing else on the car . U have to reuse the old hardware so make sure to get the two nuts attached to the old end links, the white bushing fit in the old brackets with out stretching the steel or anything i was worried that they would be too big since it a 22mm and I think the oem bar is 18mm but they fit spot on. The white line bar was tricky to slip back in i had to just send the bar in alone with no end links or brackets attached to it for clearance and even then it was hitting everything thing and getting stuck but I got it in there. Once it was in and all the hardware was attached again I went to Azusa canyon for a test drive. The car felt great i had to get use to how fast n quick the car cut in a turn ,the car felt planted and stable like never before it reacted totally differentin a good way though. I had to adjust my driving style honestly like when I started to turn in to the corners at first I was used to the sloppy oem bar which I always had to turn early to end up in the right place for the exits of the turns but now if I do a early turn I’ll slam into the mountain wall or straight off the cliff. She cuts corners like a laser beam now n i love it I can really treat her rough and she likes now . I highly recommend to you guys 22mm rear sway stiff setting with the accord end links even if it is not white pick one up 22mm steel is 22mm steel no matter the brand you will be happy with the result
