BriteBlue
- Jul 6, 2018
- 30
- 847
- 401
- Illinois
- 2018 Civic EX-L
The 25,000 miles is correct, but only in one scenario.The Honda maintenance schedule calls for CVT fluid changes every 25,000 miles. If people never change the fluid then they should expect to replace the transmission at around the 100k mark.
I contacted Honda when I bought the car & asked about the maintenance schedule like I’ve always had with other cars. They replied:
“Your vehicle utilizes a Maintenance Minder system to advise when regular services….”
“Therefore, there is no set maintenance schedule; the exception to this is the numbered items found at the bottom of page 515.”
The bottom of page 515 states:
Continuously variable transmission models
Driving in mountainous areas at very low vehicle speeds results in higher transmission temperatures. This requires transmission fluid changes more frequently than recommended by the Maintenance Minder. If you regularly drive your vehicle under these conditions, have the transmission fluid changed every 25,000 miles (40,000 km).
Of course there is no harm in changing trans fluid more often. I used to change engine oil every 1,000 miles. But over time it became 2,000, then 3,000, etc. Now I tend to follow the manufacturer's recommendations due to improved oils & higher accuracy in the manufacturing & machining of parts.
