That is all correct.ok so planning on keeping the oem wheels for now
looking for some wheels spacers
did some research and this is what i found....
OEM specs:
5x120mm pattern
64.1mm hub bore
14x1.5 lug studs
can someone confirm this before i hit place order button..LOL
OEM specs:
5x120mm pattern
64.1mm hub bore
14x1.5 lug studs
Just FYI, you're going to increase torque steer and partially undo all the great engineering honda did to get torque steer to a minimum. Engineering > whether the wheels are flush.ok so planning on keeping the oem wheels for now
OEM specs:
5x120mm pattern
64.1mm hub bore
14x1.5 lug studs
yeah already felt the torque steer just a bitJust FYI, you're going to increase torque steer and partially undo all the great engineering honda did to get torque steer to a minimum. Engineering > whether the wheels are flush.
Are you running OEM wheels? Do your wheels not have the pocket/void between each lug like pictured here? Just curious why yours wont fit but others have seemed to have no issue.yeah already felt the torque steer just a bit
the plan was to install 20mm spacers BUT the oem lug studs hit the wheel even with a additional 5mm spacer (25mm total)..so only installed the 5mm and you can feel a hint of torque steer...also did alignment (which was already off)...the car has a lot of negative toe so toe was adjusted just a bit to extend the life of the tires
They are talking about the Type R. You wont have that problem with your FK7Are you running OEM wheels? Do your wheels not have the pocket/void between each lug like pictured here? Just curious why yours wont fit but others have seemed to have no issue.
Well that changes things. Thanks bud.They are talking about the Type R. You wont have that problem with your FK7
