CVTKiller
- JT
- May 25, 2021
- 9
- 98
- 63
- Miami
- 2019 Civic EX-T CVT
Whats Up! So last night. I was messing with my Ktuner view and starting looking at the different parameters and was wonder what everyone else is displaying and why?
What is most relevant to you and your car when Driving or racing? lol and Why?
Any parameter that are overlooked when monitoring you car that should be on.
and to go really deep if any fan boy has the “normal” or healthy values for all of these would be extemly helpful
RPM - Revolutions Per Minute
MAP - Manifold Pressure
TC.Target - Turbo Charger Target(Not available on all platforms)
TC.Press - Turbo Charger Pressure (Not available on all platforms)
TPS - Throttle Position Sensor
TPS.C - Throttle Position Commanded
ECT 1&2 - Engine Coolant Temperature
IAT 1&2 - Intake Air Temperature
A.Ignition - Actual Ignition Output
Wideband - Factory Wideband Value
VSS - Vehicle Speed Sensor
CAM In.A - Intake CAM Position Actual
CAM In.C - Intake CAM Position Commanded
CAM Ex.A - Exhaust CAM Position Actual (Not available on all platforms)
CAM Ex.C - Exhaust CAM Position Commanded (Not available on all platforms)
Battery - Battery Voltage
K.Cont - Knock Control Value
K.Count - Knock Count
K.Cycle - Knock Control Cycle
K.Ret - Knock Retard Value
EWG.Duty - Electronic Wastegate Duty Cycle (Not available on all platforms)
EWG.Posi - Electronic Wastegate Position (Not available on all platforms)
EWG.Target - Electronic Wastegate Target Position (Not available on all platforms)
DIFPress - Direct Injection Fuel Pressure (Not available on all platforms)
DIFP.Target - Direction Injection Fuel Pressure Target (Not available on all platforms)
Ethanol - Ethanol Content (Not available on all platforms)
STFT 1&2 - Short Term Fuel Trim Bank 1 and Bank 2
LTFT 1&2 - Long Term Fuel Trim Bank 1 and Bank 2
FPS - Frames Per Second Refresh Rate
