What oil is everyone using ?
dem2757
MD
2018 FK7
Motul 0w20 ecolite but really anything that is synthetic is fine.
I use Motul purely for the built in pour spout!
mmc21
Mitchell
Knoxville, TN
2021 Civic Type R, Boost Blue
Mobil 1 @ costco $32.99 for 6 quarts
The Kirkland Signature is also very good. My research says it is from the same distributor/manufacturer as Amazon basics oil. They have both shown to be very, very comparable to top oil brands and meet all revelant API testing. 10 quarts for like 26$.
FK8CW2019
Lee
Saigon
Civic Type R
I'll give it try next time
xdecemberguy
Randrew
Honda Civic Type R
I see a lot of people using synthetic 0w20 but not all 0w20 oil is SN plus rated for turbo charged motors. Making sure your oil is SN plus the oil is manufactured for turbo charged motors to prevent pre-detonation in the combustion chamber in your car.
courrey
Correy
2021 Honda Civic Hatchback Sport 6MT
Castrol Full Synthetic 5W-30, and OEM A02 Oil Filter
Warpspeed
Noel
Norcal
2003 Evo8, EF Civic Si, and 2020 CW Civic Type R
Eneos with Purolator Boss filter.
Honda Civic 10th gen What oil is everyone using ? 20211119_122034
AlphaDigital
Alex
MW
civic
Mobil 1 and wix but since tracking the car ive switched over to Motul 300v.
RTC975
Ceti Alpha V
2019 SGP Type-R
Literally ANY oil with a Dexos 1 Gen 2 or 3 label on it will be fine - use with confidence as you or your engine won’t know the difference. I’ve run Pennzoil Platinum and am currently on a Valvoline Extended Protection fill.
I change between 5-6000 miles every time. Oil is cheap, engine work is not.
Bman90
Brian
Chicago
2020 Honda Accord 2.0t
:bow: Old head knows what he is talking about
Yes but I’ve seen oil analysis on the 2.0t Accords like I have and Civic Type R using 0w20 and they shear down to a 0w16. So my best guess would be to use a regular 0w20 fully synthetic and do more frequent changes 3000 miles or do depending on if you race or not or a 5w30. The fuel dilution and shearing of some 0w20 oils makes them thin out a lot !
Bman90
Brian
Chicago
Does it have to be SN plus? Because I know Redline standard and their racing oil is not SN plus probably because of their high contents of anti wear additives (Zinc) which can cause issues with the cat on the car. But I’m sure high performance oils that are not SN plus are suitable for turbo engines.
Has anyone done an oil analysis on here? I don’t have a Type R but I got the K20C4 in my Accord which is similar I’ll be doing an oil analysis soon and then I’ll see if I’ll stick to 0w20 or go 5w30!
Bman90
Brian
Chicago
That’s some good oil. Are those Purolator filters high flowing like the K&N filters ?
RTC975
Ceti Alpha V
2019 SGP Type-R
Some can shear def. Thats why i’m a 5-6k change at most. My preference. It doesn’t go below 50% in the minder. Besides, I like crawling under and getting eyes on the drivetrain at regular intervals in case something pops up.
TypeSiR
On a Twisty Road
1.5T Civic, Fit, MX-5, CTR
SmokeGhost
Ft worth, TX
2021 civic type r
Gf-6 oil with 5k oci and your good. Gdi turbo cars are hard on oil and will lose viscosity over time. Especially pennzoil.
go to bitog.com for good info
