coleman17
I don't really pay attention to speed until I get to cruising speed. I usually shift around the 2,800 RPM range. On the highway/interstate, I shift into 5th at my desired speed and cruise if the speed limit is 55 or below. If it is higher I will go to 6th and cruise.
I never accelerate more than 2-3mph in 6th, or 5th for the most part (speed dependent). I will shift to 4th if I have to accelerate. I guess I kind of look at 5th as my overdrive, and 6th as my second overdrive, if that is at all logical.
Around the city, I will rarely go further than 4th. Basically, my goal is to keep the RPM around 2.5k. I have done minimal research on this, and this is my first turbocharged car. I have driven a manual since I started driving in 2008.
Am I shifting in a correct way for a turbocharged car? I never really put much thought into shifting until I got this car. I always just went with what would "feel" right. From what I have read I've seen you shouldn't apply heavy acceleration in high gear. i.e. flooring it 6th while cruising at 55 to get to 70. But rather do as I am, and change to 4th to get to your desired speed. Essentially keeping the boost in the negative while in higher "cruising" gears to keep strain off the engine.
Please correct me if I am not on the right track here.
