redcivic19x
- Josh
- Oct 20, 2019
- 22
- 336
- 225
- FL
- 2019 Honda Civic SI Sedan
- #76
I always read it was bad to skip gears.Just stay in the gear you were in until you have reached the desired speed, then shift to the gear you need for the road speed and rev match.
If I'm in 4th gear at 50 kph and the turn requires me to be driving at 20 kph, I slow down to 20 kph, skip shift to 2nd and rev match my road speed. I don't need 3rd gear at all.
If I'm driving 70 kph in 5th gear and I need to slow down for a turn that requires me to slow down to 20 kph, I slow down to 20 kph, skip shift to 2nd and rev match. I don't need 4th or 3rd gear at all.
This is for all gears unless the RPM would cause the engine to lug while in a higher gear, in which case you just clutch when the RPMs are just above idle and hold the clutch for a tad longer as you're slowing down before rev matching.
If I'm required to stop, regardless of the gear I'm in, I slow down until the RPMs are just above idle, clutch and at 5 kph or less, put just light pressure on the shifter and it slips right into 1st. If I know I'm going to be sitting at a red light, instead of putting in it 1st, I put it in neutral and relax the clutch.
The key to driving manual is to shift when you need to, not when you want to:
Slowing down: same gear I was in when slowing down, down shift once to desired gear, rev match, accelerate away.
Speeding up: Shift at low RPM, smoothly, don't drag the clutch, stay in the gear that achieves the best fuel economy for the given speed and grade. Or you can skip shift. Wind the gear out more and shift up 2 gears, such as 2nd to 4th, or 4th to 6th (4th to 6th is more common for me if I had to speed up quickly from 4th - I will just drop it in 6th).
Sometimes people think too much, waste gas, wear clutches, wear synchros.. There's really no need for that when you're daily driving. Just be gentle with it. I guarantee it will cost you $10,000 less over the car's lifetime if you just drive it right, and that's not including if you blow it up or break something. I'm just talking about wear items.
can you clarify (or someone else) why people shift at such low RPM bands?? I find it way mite difficult to shift at low RPMs and if I do, I end up riding the clutch a lot longer than if I shift at a higher RPM band. even just casually driving I am still shifting around 2700-3000 RPM (except from like first to second which I’ll normally do around 2000-2500). and then I read where people are shifting around 1500 RPM and i guess it doesn’t make sense why people would shift so early. Any explanation would be great. Just very curious. Unless it’s strictly a personal preference, then disregard my question. I just want to know if there is a specific reason for shifting at such a low RPM band.
