What is the highest RPMs’s my L15B7 can run on stock parts.
Odarabla
Eric
Madisonville
2019 Civic SI
I have a 2019 Civic SI with a KTuner and TSP stage 1 tune. I was wondering if anyone has played with the redline of these motors yet. 6500rpm redline just seems really low. I would love to carry this thing to 7k or higher. Has anyone messed with this yet? If so what were the results? How many RPM’s can the stock motor take? Thanks
amirza786
A
Northern California
With the current stock tune, 6500 RPM, and with TSP's Stage 1 tune, 6500 RPM. Even if you were to move the redline to 7K you would not gain anything due to the limitations of the stock turbo while putting stress on the engine. When you would want to raise the redline is when installing a bigger turbo and of course getting a custom tune. In that case you would move the powerband higher into the RPM range so that you don't throw your rods and or cause excessive torque steer/shred your tires, as this is a FWD platform
Odarabla
Odarabla
Eric
Madisonville
2019 Civic SI
I was curious to know with the tsp stage one tune if I could make a little More power with the factory turbo by increasing the RPM’s. Do you know if this theory has been truly tested or if it’s speculation at this point? Thanks for responding.
MaxPower
NJ, USA
2020 Civic Si sedan ABM, 2017 CR-V EX, formerly 2005 Saab 9-2x, 1986 Prelude Si
Peak power & torque both occur well before redline. You won't gain anything by revving faster, except some unnecessary engine wear
amirza786
A
Northern California
The way TSP is able to get more power is to increase boost and throttle response, not RPM's. By increasing and holding boost a little longer, more air and fuel can be crammed in. There are additonal bolt-on's that can increase power even more such as DP, mid-pipe, flex fuel kits etc, but these require tunes that will push the power higher into the RPM range. To be able to get more power from higher RPM's, you need a bigger turbo
Odarabla
Odarabla
Eric
Madisonville
2019 Civic SI
Okay, so I have my answer and a path forward. Is there much doubt to run this little engine up to 500whp reliably? I’ve owned fast cars in the past and just getting into the Honda stuff. My last car was a 9 second 4th gen Camaro.
arpypat
Civic
Stock internals can't safely handle more than around 350tq. As some members on this forum experienced firsthand lol. I think 300whp/300tq and upgraded clutch is the sweet spot for this lightweight FWD platform.
Rich19Si
Richard
Ft. Lauderdale, FL
2019 Civic Si Sedan
That’s a very expensive question, it’s best to do some research in the Si motor’s capability instead of relying on some answers from random people on these forums. Just my 0.2 cents.
amirza786
A
Northern California
I wouldn't run this engine at 500whp without building it's internals out first. In fact I wouldn't run a fwd platform (or something this light) with that much power period. That's just my .2 cents as well
saiko21
Sai
Sacramento
2019 Civic Si Sedan (Sold) , 2005 Toyota Corolla (Sold)
There's no reason to increase the rev limit of these engines as the power drops after 5,500 RPM.
Odarabla
Odarabla
Eric
Madisonville
2019 Civic SI
I understand that. I called PRL and asked this same question. I plan on building the engine to handle the power. Either that or just buy a type R to play with. I’m
