Question... in the "Most Beneficial" table, you list Ethanol, methanol and race fuel on the same line, but in the table Estimated Horsepower you don't mention race fuel (100 octane?).
Race fuel is the hardest to come by and I have the least amount of data on that, but it should get you to 400.Question... in the "Most Beneficial" table, you list Ethanol, methanol and race fuel on the same line, but in the table Estimated Horsepower you don't mention race fuel (100 octane?).
When it comes to HP/Torque, are the outputs very similar to Flex fuel?
I wonder because I have a station with race fuel just down the street, and if I can get near to 400 HP with just a downpipe and tune and race fuel.... That would be pretty affordable and easy for me...
https://www.civicx.com/forum/threads/fs-modified-2018-type-r-aegean-blue-metallic-dfw-tx.53892/Lol . What kind of mods you got in your fk8?
So, will the stock ECU tune itself to 100 octane? Any idea? Any idea what HP/Tq one would get with a stock R (no tune) running race fuel?Race fuel is the hardest to come by and I have the least amount of data on that, but it should get you to 400.
According to this document from the US Department of Energy, each additional 10% of ethanol increases octane levels by 2-3 points, with 100% ethanol being 113 octane.
If you take 93 octane and add E85 to it to make it E30 (the ideal ratio for an R without an aftermarket fuel pump), it should be about 99 octane, having the equivalent detonation resistance of race gas.
It's INSANELY more expensive to run race gas than a 93-E30 mix, though. On the other hand, race fuel may have a benefit in that you don't have to reduce boost like you do with ethanol and it will probably get you even further than 400. Ethanol requires more volume, so our pumps get tapped out even earlier. Not so with 100 octane.
I'd go fill up a tank of 100 octane myself to find out how it compares to E30, but my wife would kill me if she found out I filled up a $100 tank of gas.
Trade for a Mustang GT.
No, it will not. To see the benefits of higher octane fuel requires a custom tune. You will see zero gains otherwise.So, will the stock ECU tune itself to 100 octane? Any idea? Any idea what HP/Tq one would get with a stock R (no tune) running race fuel?
I mean if the ECU is so smart as to tune itself to 100 octane and I only have to do it when I want and its going to give me something like 350WHP... like track day or once in awhile to find out... And if I don't tell my wife...
(edit: only 91 octane in AZ. Maybe some E85, but I know where 100 is!)
You're most likely getting some knock on 91 (pulling timing), therefore, making slightly less than what the ECU is capable of.So, will the stock ECU tune itself to 100 octane? Any idea? Any idea what HP/Tq one would get with a stock R (no tune) running race fuel?
