I know they add cleaners to premium gas. Does it really work?The previous owner used regular gas, My injectors looked BAD when I took them out and replaced them, major carbon build up.
I was recently in AZ for a while and found a Love's gas station that sold 100 octane Sunoco unleaded racing gas. You could see if that's available to you locally and boost your premium with 1 or 2 gallons of it. In general the 91 oct premium I found from many stations in AZ was garbage and led to knock control swinging all over the place, higher than I had ever seen at home before.Ran 87 in mine until I tuned the car with Ktuner. Now I use 91 only, to keep Knock control down. (93 not available in AZ).
Then what works with these direct injection engines?Fuel injection cleaners don't really do too much in direct injection cars. It will clean your injectors, but you can't clean out the carbon build up on the valves anymore by an additive in the tank. Direct injection system sprays the fuel directly into the cylinder instead of before the valves.
I think they figured out the injectors spray angled onto the intake valves.It will clean your injectors, but you can't clean out the carbon build up on the valves anymore by an additive in the tank. Direct injection system sprays the fuel directly into the cylinder instead of before the valves.
Thanks for the response here! My K. Con stays between .49 -.54 at the highest with Shell 91. I can’t believe you found 100 octane out here! I’ll have to do some research in seeing if there’s anything like that locally in the PHX area.I was recently in AZ for a while and found a Love's gas station that sold 100 octane Sunoco unleaded racing gas. You could see if that's available to you locally and boost your premium with 1 or 2 gallons of it. In general the 91 oct premium I found from many stations in AZ was garbage and led to knock control swinging all over the place, higher than I had ever seen at home before.
I have TSP stage 1+ for Si and I normally use 92 oct premium with a gallon of E85 per tank, and my knock control never moves.
