David16touring
- Mar 12, 2017
- 6
- 83
- 56
- Waukegan IL
- 2016 Civic touring, 2014 Mazda CX-5 Touring FWD.
- Vehicle Showcase
Hey guys, so I will be getting my leaking head gasket replaced as soon as it comes in from cometic. I was wondering if there’s anything else that should be replaced while my motor is half torn apart lol.
I already have small list of parts that I already ordered/ have in my possession:
Head Gasket from cometic
Valve cover gasket also from cometic
Fresh set of new OEM fuel injectors( I run ethanol and want to have piece of mind and also when I try to do a pull on ~30% ethanol the car feels like it’s breaking up but when I do a pull on full 93 It doesn’t feel as much but you can still feel it)
Fuel joint pipe to prevent any leaks. (Per recommendation from local Honda dealer)
Throttle body gasket and intake manifold gaskets(Also recommendation from Local Honda dealer)
Head bolts
Not a part but getting a valve adjustment done as well.
Non-necessary items also getting done at the same time ?
Installing 62A Rear motor mount from Hasport
Getting my catted PRL catted downpipe put back on since I had to take it off for emissions.
Any inputs for necessary and non-necessary items would definitely be appreciated! If it helps I have a 2016 Honda Civic touring with the CVT.( and yes, I’ve already had to replace my trans after beating on it so much after getting my flex fuel kit installed lol)
Hope all of my fellow CivicX owners are staying safe!
Head bolts
