Yes, it does also lower the RPM as a gear change would.'gears' as in artificial gear change pause/jerk feeling just to get the feeling of a gear change?
I think most people's problem with sound enhancement is when it's done digitally through the car's speakers. I don't see as much backlash when it's just physical sound tubes that do the job.Now how is this different than a sound symposer/fake engine noise... or is it? asking for opinions on whether this type of artificially programmed effect would bother anyone since a lot of people seem bothered by having recorded engine noise coming through the speakers.
Per Honda (in regards to the Fit)From what I read CVT is like one long gear, so what are the paddle shifters that come with it for?
Well guess that settles the debate whether engine braking is bad or notPer Honda (in regards to the Fit)
The CVT transmission can be controlled with steering wheel-mounted, dual-mode paddle shifters to provide a more engaging driver experience. D mode is fully automatic; however the paddle shifters can be used to downshift the transmission for greater engine braking for situations such as descending a steep hill. The transmission can also be upshifted in D mode. When the paddle shifters are used in D mode, full automatic operation will resume after a short time. For spirited driving, S mode includes seven ratios and maintains the selected ratio until the driver operates the paddle shifters again.
