What did you do to your Type R today?
roro40p
dallas
2018 TYPE R-11883
Happy to report that I have not rubbed at all yet. I have had my 180 lbs buddy and a 6FT butcher block inside and still didn't rub.
I think the /40 is what's making you rub.
probably ... I mean its not bad it hardly happens and I have to be loaded but still its annoying when it does lol....thx
SmokeGhost
Ft worth, TX
2021 civic type r
Did you notice a difference with the filter?
having driven a little bit since install. i dont know if its just because texas is starting to cool down now or if the filter made that much of a difference. wot makes nice turbo spooling sound; can hear the bypass valve now with enough load. pulls a little harder in each gear, especially on the highway. its nice improvement overall.
disgraced.fk8
IG: @break_ya_neck_fk7
Drew
Rochester, NY
2021 Boost Blue Type R
Can confirm 255 40s will almost certainly make you rub at some point depending on the sidewall profile, but always being in R mode helps a lot. I almost never rub now that I'm always in R mode.
SmokeGhost
Ft worth, TX
2021 civic type r
i have the same size tire and i dont rub at all. conti dws06 p. im not lowered. not tracking if you are. my wheels are 18x9 +45 so that may be why i dont rub.
MoodySara
Paul
NH
2021 Type R - Boost Blue; 2024 Civic Touring - SGP
Installed the winter tires - Enkei SS05 18x8 40mm with 235/45R18 Continental VikingContact 7.
Drove about 100 miles in heavy rain/wind and 40°. Lots of wheelspin at launch and even in 2nd and 3rd if I punched it at all.
Lateral grip seemed good even with lots of wet leaves on the road. I tried a couple of hard braking tests. Those seemed good, too.
Tanilroy
So Cal
2019 Type R (Championship White)
OEM Honda homelink upgrade.
Honda Civic 10th gen What did you do to your Type R today? 60037496-E5C4-49A2-AB3B-336EF3A5BE22
Link to part
https://www.oempartsource.com/oem-p...avigation-nh167l-graphite-black-36650t2aa11zh
Recommend: Having a 5 pin Acura/Honda Homelink adapter like this made electrical set up so i didn’t need to modify existing wires; just carefully insert wire from this adapter’s Pin 1, 2, 4, 5 into appropriate existing colored Honda wire (connections below).
https://www.ebay.com/itm/5-Pin-GRAY...2349624.m46890.l49286&mkrid=711-127632-2357-0
Wiring connections:
Adapter Pin 1 to Honda Blue wire
Adapter Pin 2 to Honda Black wire
Adapter Pin 3 (omit)
Adapter Pin 4 to Honda Grey wire
Adapter Pin 5 to Honda Red wire
Wiring enables map lights and Homelink operable while car is off
RepyT
Almost Stock ‘19 R on 255/35-19”
Dave
Destin, FL
2019 Civic Type R FK8, 2017 Lexus GX460 Luxury
Link to part
Wiring connections:
Clever, thanks!
Still not the right color though, needs this:
https://www.ebay.com/itm/ABS-RED-Fr...2349624.m46890.l49286&mkrid=711-127632-2357-0
