What did you do to your Type R today?
ctrmofo
planet earth
'13 lambo lp550-2, '18 honda ctr cw (r-12321), 14' porsche cayman s, '16 porsche macan s, '13 mini jcw nme stage 1, '15 audi s3 apr stage 2, '15 audi q3, '12 monster 1100 evo, '16 triumph thruxton r, deposited for '19 lambo huracan performante
luthacris
@Luthacris
Dove Canyon
2018 CW CTR #19009
Installed my Eventuri CAI today the sounds are amazing and after installing on my Type R, the quality of this product fits the bill, hopeful the hp gains are what they claim
Just ordered mine this morning. 2 day shipping. Credit card took a hit.
CWCTR2018
Colorado
CTR
What tire size are you going to run for the titans?
question is the 45 offset the way to go so tires dont stick out and there is no rubbing?
I am confused because i thought someone bought +35 offset but regretted it
also can you send a link where you got the tires and rims titan 7s? I am curious to know if it is possible to have them shipped with the tires already on
2018 CW CTR
willtheyfit.com has something you can play with - if you go wider, you need to adjust your offset to compensate. Otherwise, you'll be rubbing your suspension bits on your inside face.
+1 inch width means an extra 12.5mm on both sides of the wheel. Adjusting offset by 15mm (60mm to 45mm offset) pushes the extra width to the outside and leaves the inside geometry relatively the same (technically you'd you want 47.5mm offset, but idk who makes that). The higher your offset, the more you're pushing your wheels in. The lower your offset, the more you're pushing them out.
+35 offset is even more aggressive than +45 - it means you're pushing your wheel out 37mm from stock if you consider the extra +1 inch width. That means rubbing.
+35 offset is OK if you have stock 8.5" or 8" width. It just means your wheels will be set out farther than stock. But you shouldn't rub with 245 width tires.
wEaK Squad
*ATL*
Justin
Atlanta
18 CBP FK8
Finally installed these arms and had it aligned in preparation for wheels next week!
MonkeyConQueso
Armand
Seattle
2017 CTR
Friday was a busy day. Put my dashcam up finally (Old Shark, it's cheap but it works), and it works great after routing the cable all the way around the headliner and a-pillar. Put a protective screen on the head unit. And finally put my mudflaps on.
Iilac
Spelled with a I not a L for Iilac.
S2000, CTR, TUNDRA, MAXIMA
Added door jam accessory pieces and plate number iniengine compartment.
