l15b7allturbo
- Jun 10, 2017
- 30
- 600
- 553
- San Diego, CA
- 2017 Honda Civic Si
Got it tinted today.. 20 percent all around
It supports all that. You can add either the Metra AX-TOYUSB or PAC Audio USB-TY1 to retain the stock usb connection.Which features does this set of components support? (Bluetooth, steering wheel controls, backup camera, USB)
I had trouble finding a setup that supported everything.
I got you. Here's the wiring I used on my sport for reverse and a good spot for illumination.Well after hours of patience and hard work I'm a little upset with my radio install.... took my time thought I did everything right but my backup camera doesn't work right it comes on randomly but not when I put it in reverse and none of my steering wheel controls work...
@euicho it said it was supposed to support all those except USB but as of right now I'm having troubles
@Hmoobgreen As of right now if you can tell it didn't go too well, I hope I can get help from someone whos has done it and got it to work!
I wired mine under the dash. Annnnd I have pics! (sorry to derail!)
These are behind the drivers side panel under the steering wheel.
Here you can see both connections:
Foreground(blurry), illumination - grey wire on brown plug coming from traction control button.
Background, reverse - green wire on green plug by fuses.
Close up of illumination tap
Close up of the reverse tap
This is on the sport hatch, use at your own risk, multimeter everything to be sure yadda yadda
I hope all goes wellWell after hours of patience and hard work I'm a little upset with my radio install.... took my time thought I did everything right but my backup camera doesn't work right it comes on randomly but not when I put it in reverse and none of my steering wheel controls work...
Looks like I have a project to do once I have some free time and that sounds like all my troubles will be cleaned up, Thank you so much I really appreciate it. Yeah, i read up that people were hooking up the steering wheel controls easy and I was messing with my steering wheel controller for an hour last night trying to program over and over and it never worked.I got you. Here's the wiring I used on my sport for reverse and a good spot for illumination.
You will have to reflash the steering wheel controller and possibly even manually reprogram it. It's been a while but I think I did it using my phone with an OTG adapter and their phone app.
Also you can retain the usb! Look up either the Metra AX-TOYUSB or PAC Audio USB-TY1.
I have the leather wheel on my EX-L and it's great.Installed OEM leather wheel. Dealer wanted $200+ just for labor ... I told them to pound sand.
I didn't notice that in the poster's picture at first, but you are right.I have the leather wheel on my EX-L and it's great.
For some reason your steering wheel looks to be missing the aluminum trim piece under the airbag..
The reason for that is because the LX doesn't have that aluminum piece.I have the leather wheel on my EX-L and it's great.
