NiNi
Great, looks better than everyone just changed to red.Changed black emblem.
Thanks for thatGreat, looks better than everyone just changed to red.
I am curious to see what information the iDataLink Meastro will give to the supporting aftermarket head unit in comparison to the app there. I will be installing mine in about 2-3 weeks and I will definitely post! It taps into the OBDII and displays vehicle information like performance gauges, climate controls, battery voltage, check engine codes etc.Sitting in traffic (that SoCal life).. got a cheap android phone for my gauges instead of the 7” tablet I was using, this is SO much better. Still gotta adjust what I want displayed but so far I recommend this over a tablet
how much did they charge you to vinyl wrap the wheels? i was planning on getting mine powder coated gloss black, but may change my mind
$200 just the flat faces of the wheels, not the whole wheel.how much did they charge you to vinyl wrap the wheels? i was planning on getting mine powder coated gloss black, but may change my mind
That looks really nice!!red trim added to the dash had it forever and finally got it on
Nice!!Matching the back seat trim to cf like the front. First time wrapping things.
I’m curious about that idatalink myself hahaha.. not sure what it is. What aftermarket HU are you running and is that device just to display info? I’ve got my ktuner plugged into my obd and connecting w it through BluetoothI am curious to see what information the iDataLink Meastro will give to the supporting aftermarket head unit in comparison to the app there. I will be installing mine in about 2-3 weeks and I will definitely post! It taps into the OBDII and displays vehicle information like performance gauges, climate controls, battery voltage, check engine codes etc.
May I ask what did you do to the turbo?Just a little upgrade in the works
I wrapped them without removing the trim. Having a plastic flat head helps with tuck in the wrapper.Nice!!
Do you wrap it with the trim on or do you take it off and wrap it ?
Thanks
I also did the shifter bushings. Huge difference. I was considering shortshifter but after changing bushings I’m ok.Looking good @ck42 ! And that is exactly my line of thought as well regarding pulling up the center console. I want to do the bushings AND rocker at the same time. Wonder what the ETA on the rocker is.
How do you like the new shifts? Noticeable change?
The Compressor wheel was changed out to a 11 Blade Billet alloy design with a larger size compared to the OEM 6x6 Cast compressor wheel...May I ask what did you do to the turbo?
sorry for being a noob.. does it give you more boost? thanksThe Compressor wheel was changed out to a 11 Blade Billet alloy design with a larger size compared to the OEM 6x6 Cast compressor wheel...
Yes.. to some degree and it will flow a lot more air compared to the stock turbo so the power band will not fall flat on it's face after 4800-5200rpmsorry for being a noob.. does it give you more boost? thanks
