AndrewsCivicSi
- Andrew
- Mar 30, 2020
- 2
- 34
- 41
- San Diego, CA
- 2020 Civic Si Sedan
Installed oem clear corners. No dremel required! Swapped right in.
Looks good. But why would a Dremel be needed for any side marker install?Installed oem clear corners. No dremel required! Swapped right in.
Yes if you get the ones made in TaiwanLooks good. But why would a Dremel be needed for any side marker install?
Are they as bright as the LasFit? I like my headlights but I think I need to dubbed down a little bit. They are blindly bright lolInstalled Katana LED bulbs recently. Love the improvement in illumination of the road at night.
Looks good im waiting on mine from @artofattackInstalled oem clear corners. No dremel required! Swapped right in.
Looks nice! I did the same last weekend, only I went with the Seal and Shine. Not sure of the difference between the Ceramic you used or the Seal and Shine I used. I did two coats as well and am very happy with the results.Just bought and used Turtle Wax Ceramic spray for the first time. Wow, I love it. Took about an hour to install. I'll probably do the recommended 2nd coat tomorrow. The gloss is ridiculously shiny.
I just bought the same stuff but haven't used yet. Did you clay first?Just bought and used Turtle Wax Ceramic spray for the first time. Wow, I love it. Took about an hour to install. I'll probably do the recommended 2nd coat tomorrow. The gloss is ridiculously shiny.
Looks good. I have never used this but I have seen it at Walmart. I used CG’s extreme top coat sealant and the wet mirror finish glaze. I made a mistake and put the sealant on first instead of the mirror wet glaze ??‍Just bought and used Turtle Wax Ceramic spray for the first time. Wow, I love it. Took about an hour to install. I'll probably do the recommended 2nd coat tomorrow. The gloss is ridiculously shiny.
But the guy at the detail garage said I did it backwards? He even gave me a card with the flow chart and it said the sealant is supposed to go on after the glaze. Sorry I messed up and said “wax” not glaze. Yes the product I have is the glaze not wax.Jen. Actually sealants go on before wax. Wax is always the final step.
You're 100% fine. You did good.
Don't redo it with sealant on top. If you do, I'll be forced to remind you that you did it backwards.
