Water/Meth Kit?
Rickyshoots
2019 FK8 Black
Ricky
Huntington Beach
2019 Type R FK8 SBP,E-250 cargo van,
have any of you done this im thinking with all the Mods my car currently has when PRL drops the new turbo upgrade I will also do the water meth kit it seems like a safer route than E85 with the new turbo
  • Like
Reactions: EdG
highlander
stefan
nova scotia
2010 civic Si,2017 civic type r
I run water/meth on my 8th gen and I love it... once I get a bigger turbo on the car im going to run 100% meth on it...
kimtyson
Kim
York, Pa
2018 Civic Coupe EXT
Meth. Sounds like a real expensive habit.
remc86007
Ryan
Jacksonville, FL
2018 Civic Type R
I have it on my mostly stock R with the ktuner 1.1 tune. I use the smallest nozzle available and have it activate at 16psi. It does a great job of dropping the intake temps when taking off from a light in super hot Florida. It brings the intake temps down enough that the ecu adds power back to close to normal (cool iat) levels. I have done data logs and you can definitely see the difference when it activates: 1. The intake temp drop is fast and dramatic (30+ F drop) 2. the fuel pressure doesn't drop as much while maintaining the same A/F ratio since some of the fuel is being provided by the meth 3. The ecu adds back some of the timing and manifold pressure that it would have pulled otherwise due to high IATs.
fk8mike
canada
civic type r
i would't use meth has a power add on,but iats/octane/cleaner way,setup is basic,12psi the spray is on,50/50 mix,
Chumbaloo
Steven
Plano texas
18 civic type r grey
Where do they install the nozzles as I’m thinking I’m gonna grab this in to install with my hondata fuel kit
Do they inject it through the charge pipes as I have the prl charge pipes?
remc86007
Ryan
Jacksonville, FL
2018 Civic Type R
I just drilled and threaded a hole on the charge pipe about inline with the space between the battery and intake box.
Tim818
King Of The ‘Ring
Texas
2006 Civic EX, 2018 CTR
If I’m not mistaken the PRL charge pipe has a bung for meth injection already.
