Its just an alert, hey you left your keys in the car, oh your proximity lock didn't work you have to lock manually.What is this rapid beeping? A big in the software?
This occurs when I close the door if the key fob is inside the car. This also occurs sometimes when the key is inside my pocket. When this happens, I have to lock the car manually using the key fob.
It means they are not locked. When you hear them try the door it should be opened. But if the car locks correctly, you will hear a single beep that says the car is ready to lock and once you are far enough away a second beep meaning the car is lock. You can check the manual too for a better explanation if you need.So, when rapid beeps, are the doors locked?
I think the autolock is just for push button start / remote start equipped models, but I'm not 100% on that.Maybe I missed something but I thought if you had the cheapie display you didn't get the walk away feature. I have the no frills display and don't see any way to disable the walk away (that isn't there) but still randomly locks the doors. Is there something I don't know?
I do have remote start but can't find any way to access the walk away settings.I think the autolock is just for push button start / remote start equipped models, but I'm not 100% on that.
I would check the manual for it, but honestly I am not sure.I do have remote start but can't find any way to access the walk away settings.
To each his own. The whole idea of the walk away feature is we can leave the key fobs in our pockets.I turned that walk away feature off in the dealer parking lot. I don't need the car to lock itself in the garage. Or ever, for that matter. Hitting the black lock button on the inside of the door on the way out works every time.
Just to clarify, I don't use the fob, so it's in my pocket where it belongs.To each his own. The whole idea of the walk away feature is we can leave the key fobs in our pockets.
So far, I am used to the 2 beeps but not the rapid beeps (key fob in pocket).
Yeah but you have to reach for it before you get into the (locked) car... that's way too much work. With that feature on, I just touch the door handle and I'm in.Just to clarify, I don't use the fob, so it's in my pocket where it belongs.
