VividRacing
- Austin
- Nov 28, 2018
- 154
- 471
- 130
- Gilbert Arizona
- FK8
VR Tuned ECU Flash for FK8
Tuning the ECU of your Honda Civic Type-R 2.0L Turbocharged engine is possible with VR Tuned. The driving characteristics are vastly improved while providing you additional benefits that your engine craves for. With this additional programming to adjust your ecu calibrations, we also make changes to the torque limiter to provide better throttle response.
Crank Horsepower Ratings:
Stock Power: 320HP | 295FT/LB
Stage 1 Power: 360HP | 369FT/LB
Stage 2 Power: 374HP | 382FT/LB
What are the benefits of VR Tuned?
#1 priority is our customer service to you!
Our tuning is used worldwide. We have powered vehicles of all types.
All ECU tunes can be reverted back to stock if necessary.
With the VR Tuned ECU Flash, basic bolt-on performance parts will not require a retune of your ECU.
Adding parts such as an exhaust, intake, plenum, pulley, will all adjust with the tune.
If you add higher octane fuel, the ECU will adjust accordingly.
We can tune cars worldwide including JDM, EU, Australian, and USA cars for different types of octane or environments.
Other custom enhancements are available if requested and applicable.
We test and dyno tune on our own cars to make sure what you get is safe, reliable, and gives you the results you want!
How to Flash Your ECU?
Use the DimSport handheld device. This REQUIRES a Windows PC. You can flash between these at anytime.
We can bench flash the ECU. To bench flash the ECU, you must remove it from your vehicle and send it to us. Once we receive the ECU, we will prepare the tune file and then ship it back to you for re-installation. We do not solder or modify the ECU board at all. All ECU tuning is done via bungy probes that have a needle tip to provide an electrical connection.
To get your car done email me at tyleri@vividracing or PM me directly here!
