Valve cover gasket leaking on '17 Type R
Tev42
Tyler
San Diego
2019 CTR
I looked under my hood, I honestly had no idea where to look still. I took some pics but idk if they show anything. Hopefully you guys can tell
Unfortunately none of these pictures show the spot. Check my picture and you will see the oil and where it sits
Page 6, post 76
phan10ms
Bay Area
'19 CW Type R, '06 AP2 S2000
Wow dood, the 5th post shows exactly where it's at which is on the firewall side as stated and yet somehow you still missed it. Hint, check around the intake manifold. Amazing.
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R 1592154679139
Zeffy94
Matt
Doylestown, PA
Page 6, post 76
I see it in your post but if neither of these two have it then idk, I matched up the locations with the pink hose looking thing
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R 8A5E5D05-25B2-44A8-A3FD-124BD1A0CDF8
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R A61737EE-AA94-41AF-A1CE-105B003561EE
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R 3070D168-8FAF-4C1A-8298-C0A7F05A586C
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R 9EB292FE-D53C-402E-B19E-41083CD76DB9
There’s a million things underneath the hood and I have barely any clue what a majority of them are. Sorry for being uniformed but I’m trying my best here. At most I doubt I have any leak because I figure oil would stick out like a sore thumb.
Tev42
Tyler
San Diego
2019 CTR
This image almost shows it, I circled the portion of the image that kind of shows it but is not very clear.
If you prop the hood up on the higher notch so the hood is as high as it can be, stand behind your front passenger wheel, and look at the corner of the engine closest to you, it is where the black plastic meets the silver metal in the blue circle
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R 1592157605411
Zeffy94
Matt
Doylestown, PA
Thank you so much for pointing it out. I’m stupid because I was using the wrong notch so I could barely see into the engine bay without running my head into the hood prop. Now I noticed the higher one and I have much better visibility. I think I captured it this time.
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R 2B850CEF-8954-435B-B260-01E87A115CDF
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R 9EA2A882-9658-4270-913D-A0E7FE531BE4
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R E9DDFD7B-0652-4823-8E12-97C5FCD72288
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R 1B5C1EBA-7BDF-4018-9208-3C7AFE013114
Sorry for being super slow at this.
Tev42
Tyler
San Diego
2019 CTR
no worries, these pictures look good. There is some sediment there but doesn’t look like the Sediment is sticking to oil so that’s a good sign!
Zeffy94
Matt
Doylestown, PA
Yep, that's what I thought. Nothing that looked like oil in that vicinity at all. Looks like I'm a lucky one! Thanks again for the help.
fatherpain
Tom
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R 062F5353-8C88-43CA-9346-A1FBDC07497B
Here is where I found my valve cover leak. Engine cover removed. Look towards the rear on the driver’s side.
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R 9017DF69-A478-4FE7-98EC-E96044DF08AB
With battery terminals disconnected, pulled this plastic wiring manifold back a little to see. This catch groove was filled with oil.
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R DCE2F978-EC43-4673-988D-B432F4E05D28
A closer look. Evidence oil leaks
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R 70DC48B7-FFCA-4C69-A4CA-5F48AEF0F647
More evidence. Pretty sure if the upper oil dripping down was due to the crappy Superstik dipstick which doesn’t seal and allowed blow by.
Zeffy94
Matt
Doylestown, PA
What build date is your 2018? I find it weird that some people have it and others don't.
Checked again, not removing anything but I wiggled my camera back there and it’s bone dry. I looked on the opposite side as best as I could and I saw nothing oily.
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R C9DAB09F-ADBC-4410-A69E-170F4C8856A2
cassidy1969
Jerry Cassidy
Porter TX
2017 Civic Type R
My 17 type r was leaking and the bolts in the rear of the valve cover were not even almost snug in fact I could turn them by hand. Tightened the bolts and it stopped leaking.
Tmy
2016 civic ext; 2019 civic type r
Just wanted to add to the collection.
2019 type r with 9k miles
Noticed it when attempting to install catch can. Anybody in Los Angeles area know a good dealer service department?
Honda Civic 10th gen Valve cover gasket leaking on '17 Type R 20200717_161732
Jt_theory
CTR
Southern California
2019 ABM Civic Type R
Wow how did I just find this thread? Too bad I didn't drive my CTR to work today. I'll have to check this out when I get home.
dwag0588
David
Chattanooga, TN
2020 CW CTR, 2014 Mazda CX-5, 2006 NC Miata, 2018 Silverado 5.3 (work)
I checked for this after my most recent autocross. No signs of any leaks on my 2020. I'm still on the factory oil fill at 1250 miles.
  • Like
Reactions: Tmy
Tmy
I didn't notice mine until 8k miles. But I never looked prior to coming across this thread a while back. Got the gasket changed under warranty. So far so good.
