Valve Adjustment needed on 2.0 L?
Steve
Michigan
2017 Honda Civic LX 2.0L
Hello Everyone:
I've been reading through these threads, and from time to time, I come across a thread where valve adjustment comes up.
Does the 2.0 in the LX require ANY kind of periodic "valve adjustment?" Someone said if vehicle has solid lifters vs hydraulic ones, it would need adjustments.
Thanks...
zspeed
Camden County, NJ
I would consult the owner’s manual just to be sure. Usually, they include that in there when to be inspected and adjusted but I might be wrong.
calonzo
New Haven, CT
2016 Honda Civic Touring
Hello Everyone:
Thanks...
This is what the owner's manual says:
Honda Civic 10th gen Valve Adjustment needed on 2.0 L? 1597062500330
DRUSA
Dan
Palm Springs, CA
2023 Civic Type R 2000 Honda S2000
Requires a valve adjustment at the 90k mile mark. It's a screw and locking nut adjuster, no hydraulic lifters or shims.
rileyj98
riley
Chilliwack, BC
2018 civic coupe
Yes you do need to adjust the valves as they are not hydraulic, this will be part of the maintenance minder 4 service when you change the spark plugs at the same time
Steve
Michigan
Ok Thanks, so to confirm, this is something that has to be done after a certain mileage, not a time thing...right? The reason I ask is that my car sits a lot as I have more than one car that I drive.
16LXMT
2016 Civix LX 6MT
Theyll say either or to play the CYA game but realistically it would be caused by RPM and engine run time. If you don't drive much I would wait until the mileage.
rileyj98
riley
Chilliwack, BC
2018 civic coupe
It will be mileage 100,000 miles/160,000km your car will let you know though if it is sooner as when the oil life monitor for your maintenance minder will pop up with a 4 along with the A/0
Pearl.FC2
Jared
Jacksonville Florida
2019 Honda Civic LX Sedan (6MT)
Hello Everyone:
Thanks...
My car is currently at a dealership for a bad misfire issue, they are doing a valve clearance test, and if it fails they will be doing a valve adjustment. My car is a 2019 LX with just under 80k miles.
BrandonSmith
The Greatest Country on Earth
2016 Civic EX 2.0L
I'm at ~180,000 miles. Manual states to check valve clearance with Maintenance Minder 4 (approximately 100,000 miles, along with replacing spark plugs). I checked my clearances at 100,000 miles and all were fine. I also have no noise to concern me.
If you notice, using a feeling gauge and your ears are both subjective - you will need experience knowing what valve noise sounds like and you'll also need to know what a feeler gauge is supposed to feel like (i.e., tight vs. loose, etc.).
