Using Genesis Brembo
Icefiyre
Austin TX
2017 Civic Si Sedan, Aegean Blue
I'm currently running gram lights 57CR 18x9.5 38. Will it clear the genesis calipers?
Also, what does the hardware kit from http://slickfabllc-com.3dcartstores.com/Brembo-Big-Brake-Upgrades_p_28.html includes? I'm trying to source the parts locally and I don't know if I need anything more than the calipers, rotors and pads.
The slickfab hardware includes the 4 mounting bolts, 2 banjo bolts, and 4 crush washers for the banjo bolts. They also included rotor centering rings.
Fc3_Si
Rdel
Sacramento, CA
07 Si Coupe, 17 Si Coupe, 19 Civic Type R
I have the genesis brembo and I want to upgrade my front brake line to SS, but does anyone know if we can use SS brake like specified for Honda or does it have to be specified for Hyundai?
Use the normal ones specified for your Civic.
Anger
Greece
I was going through this thread cause I am looking to upgrade my front brakes on my CRV. I am trying to figure out if I can find calipers that fit on the car without brackets.
I saw that you guys need 320x28mm rotors and you use Nissan Rogue ones.
FYI, the EUDM CR-V uses 320x28mm rotors with 2-piston calipers. This means you can source rotors that fit the hub (64.1mm) exactly, plus they are obviously 5x114.3. Their offset is 47.2 for those interested. The USDM CRV uses 310x26mm if I am not mistaken, so you definitely need EUDM.
If I got it right, the Genesis calipers work with 320x28mm rotors and do not need brackets to fit the Civic....
Jtantuco
luv_SIc
Delaware
2019 Civic Si
Fellas, update time! I knew the BBS RG406 (aka Mitsubishi Evo X wheels) I had for this year would clear, but wasn't ready for how much clearance I am delighted to report back on !
As a spot of context, here are my last year's wheels, Konig Freeform 18x8.5 ET35 with a 5mm spacer to clear the Brembo calipers, which makes them ET30. That's 2mm of clearance from the lowest point on the Brembos, after gaining 5 from the spacer - without they didn't clear.
Here are my new-to-me BBS, 18x8.5 ET38 wheels. The offset is 8mm higher, yet I have nearly 11mm (0.43in) of clearance from the lowest point on the Caliper! The reason for this is because I chose a wheel that starts off with a Convex spoke profile vs. the slight Concave of the Konig Freeform.
The BBS being of convex profile has a longer wheel mounting surface, and that pushes out the spokes helping clear the caliper the way they have.
There was enough space for me to slide my hand easily between the spokes and the face of the calipers!
Clearing the barrel has never been an issue with 18" wheels, but here's me with hands resting on top of the calipers, and still have wiggle room
My advice is that if you are looking at the Genesis BBK, look for Convex or Flat wheels. For any concave wheel you have to go to a 9.5 with a low offset, which still may not clear but it sure will poke, and very likely rub your fenders when you hit a bump.
Did you still need spacers with the BBS setup?
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
humza whats the offset of BBS.. need to know what is the safe offset to avoid spacers.
the offset is +38. But dont rely on offset alone because the spoke design also plays a role with clearance :)
Jtantuco
luv_SIc
Delaware
2019 Civic Si
For everyone with this setup, did anyone have issues with screeching when the car first starts at cold temps?
It goes away after about 2-3 minutes of driving but it is very obnoxious. It just started when it got cold here, before they were fine.
Edit: also I have Hawk HPS pads.
Fc3_Si
Rdel
Sacramento, CA
Mine screech when its cold, but goes away after the car is fully warmed up. However, it is normal though during cold start.
Syntek
Los Angeles, CA
2019 PWP Civic Si Sedan
Mine screech in the cold
