using 87 gas for ktuner
bob
Stabby
CA
civic hatchback
I actually have 2 questions:
1. For stage 2 dual calibration, I noticed it says factory boost in ECO mode. What exactly does this mean? Does this mean when I press the eco button, my car will drive the same as factory D mode? And when I shift into D mode, I get 21psi? If so, what happens in S mode?
Also, can I just leave the car in eco mode and just use 87 gas and only add premium gas when I feel like doing some spirited driving?
2. My car is too far away to reach my home's wifi. Can I hotspot my phone's data to my laptop to upload the tune?
87 isn't recommended for any tuned car, "eco mode" or not. The dual tune means you get 21psi normally and something similar to stock power when the econ button is pressed. I say similar because any throttle/turbo response tweaks are applied globally so it will feel quicker than stock.
S mode has nothing to do with the tune; it's strictly a transmission program.
jayy_swish
Jay
1. Means when you press Econ mode the tune reverts to “stock” programming.
I believe for k tuner it’s
Stage 0 is 87+, 91 recommended
stage 1 is 87+, 91 HIGHLY recommended
Stage 2 is 91 required
Not exactly sure though I have hondata, but if your going to tune a car I don’t get why you would want to run lower grade fuel, just stick with premium fuel unless your on a factory calibration (unless the car states otherwise, stay with premium fuel for Si and Type R)
2. yes you can.
bob
Stabby
CA
civic hatchback
2. yes you can.
I have civic hatchback, so I can use regular fuel. I plan on driving in regular mode for most of the time, so don't see why using regular fuel will be an issue. Thanks.
bob
Stabby
CA
civic hatchback
Thanks for clarifying. Follow up question, will tuning the car affect any of my stored info? For example, will it wipe my stored mpg? Will it reset my oil life indicator? I just want to cover all my bases before I buy this.
Not at all.
jayy_swish
Jay
Yes a hatchback is designed to run 87 from the factory but once it’s tuned it’s no longer designed to run on 87. I mean by all means do what you like it’s your car, but that being said ktuner says it’s doable they just don’t recommend it themselves
https://www.civicx.com/forum/threads/ktuner-stage-1-with-87-octane.21412/
bob
Stabby
CA
civic hatchback
And if you can’t afford the extra in gas then might as well keep the car bone stock to save more.
It's not about being able to afford it. I just don't want to spend more on gas if I don't need to, especially if most of my driving is going to be below 3k rpm.
CVCTURBO
VA
2018 Civic Sport 6M
My sport Hatchback requires premium gas from factory.
Also if your planning on spending $450+ on a Ktuner, can't you afford the extra $1.37 every time and fill up with premium?
bob
Stabby
CA
civic hatchback
I have a sport hatchback too. Premium gas is not required, it's recommended for the full 180 HP as mentioned in the manual.
Assuming I drive 12k miles a year, it can add up to $120. I don't want to throw away $120 for no reason.
The reason is to get more "smiles per gallon". Well worth the extra $10 a month.
bob
Stabby
CA
civic hatchback
I agree. However, like I've said, I will add premium gas if I feel like taking my car out for a fun drive. For normal driving, like to the grocery store, I have no intention of driving it past 3k rpm, especially since my engine will still be cold.
jayy_swish
Jay
Be sure to have an empty tank when putting in premium or at least a quart tank till empty to optimize your tune, if you fill up with half a tank or less you basically made mid-grade fuel and will still get timing Pulled back
