Ah i have pure 93 here as well. So your saying not really a big difference between flex fuel and pure 93?It's really not needed at this time. I have really good 93 pumps in my area and can make the same amount of power. I might revisit e85 when there are aftermarket hpfp's that can run more ethanol and not run out.
Bone stock its ok, once you start adding mods you will have to lower boost because you don't have enough fuel pump. Most of the flex tunes tunes run less boost and more timing and leaner afr's to put less stress on the fuel pump.Ah i have pure 93 here as well. So your saying not really a big difference between flex fuel and pure 93?
Got ya that was what i wa thinking and was another reason I was holding off. If you have no mods then this is a big bang for buck and well worth it. but if you have other mods like me and a full set like me then this won't really show much of a difference not until more supporting mods are developed. Thanks for the info. I guess for me, like you, its not really a worthwhile investment. But someone who has no mods this would be a great deal and well worth it. it will make someone happy and at a great price. thanks again.Bone stock its ok, once you start adding mods you will have to lower boost because you don't have enough fuel pump. Most of the flex tunes tunes run less boost and more timing and leaner afr's to put less stress on the fuel pump.
