U129E
AmaiX
Maui, Hawaii
Civic Sport Hatchback
Car shot this code out a few times while reflashing. Now I can't open rear hatch or use fob to unlock. I am able to get in with a physical key. I would like to mention that the OBD2 wasn't giving enough power to v2 unit before I started the reflash (which confused me, and raised a cause for concern)
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
Sounds more like your battery is dead, since an ECU code wouldn't be the cause of your FOB not working.
If the V2 was having trouble powering that further supports the theory.
AmaiX
AmaiX
Maui, Hawaii
Thank you for the quick reply! I've also noticed the battery dropping to under 14v some days, and shortly returns to 14v.
It just struck me as odd that the car/battery just made a year. I have been able to drive it with no issues. However this is the first time I've been unable to use the fob to unlock. I did also notice I can't unlock the car with the buttons inside/nor open my rear hatch.
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
If you can start the vehicle and drive then it's not the battery. You said you weren't able to power the V2 properly via the OBD port, which along with the other issues suggests it is.
Check that the port isn't damage and the cable is plugged in properly. There's a disable for U129E in the software.
The FOB has nothing to do with the ECU or tuning. You have another issue if your FOB isn't working.
AmaiX
AmaiX
Maui, Hawaii
Appreciate you responding over the weekend! I actually did figure out the issue and it was a blown fuse. Unfortunately after replacing the fuse, and starting the car it resulted in the death of my Ktuner.
I did notice that this unit did occasionally lose power every now and then when I initially purchased it used. The cable into the unit looked kind of funky... On the plus side I was able to flash to stock, but unsure if I was able to unlock before the untimely event.
Honda Civic 10th gen U129E 836F1A93-708E-4EEE-98A7-6A322DB9ABBE
Honda Civic 10th gen U129E BDA46F41-E8DA-4B62-93EB-4E64E82A2562
AmaiX
AmaiX
Maui, Hawaii
Update: Was a able to boot it via USB port, but intermittently flickers on and off making it hard to navigate the menus. I did however verify that it is still locked.
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
Feel free to contact support directly.
Flickering via USB means the device is not getting enough power through that port. If you mean turning off the display, it will do that when connected to the software. Don't connect with the software and it will not go into that mode.
AmaiX
AmaiX
Maui, Hawaii
Thank you! I appreciate you greatly! You have a good rest of your day ??
Beardedfk7
Byron
New Orleans
2017 civic sport 1.5l turbo
BRO IM HAVING THE SAME PROBLEM!!!
which fuse was it?
hoping for a reply!!
@KTuner do you know which fuse it is this would effect?
Titoo
Antonio
2020 civic si sedan
@KTuner just had this same problem, v2 wouldn’t power on and just flashed the light and followed with finding a blow starter fuse.
BakaSupreme
Chad
College Station, TX
2019 Civic Sport Hatch
Did anyone here end up having any lasting problems? I had the code show up today after flashing the pherable 1.5 non-si tune. The code showed up on the tuner but not the dash. Car drives fine and operates normally but is it possible tuner caused that false flag?
Similar threads
