type r wheels for autox
phillystyle17_si
Romeo
Philadelphia
2020 Honda Civic si coupe, 2020 honda civic type R, 2019 honda civic type R
What wheel size and tire size are people using for autox? I have a 2017 honda civic type r with full bolt ons and ktuner. they class me in dsp. but right now i'm in smf because no one is in dsp. im looking for a good setup. I also daily my car
RacingManiac
Jen
Detroit, Michigan
2016 VW GTI, 2018 ABM CTR R-17001
most of us are in D-street so we are stuck to stock width and -1" from stock diameter
phillystyle17_si
phillystyle17_si
Romeo
Philadelphia
what bolt ons do you have? sounds like the car should be in STU.
I have prl dp + fp, prl intercooler, ktuner, mishimoto intake and res delete. stock suspension, 18" x 8 wheels that i use for the winter but looking for something for autox
RacingManiac
Jen
Detroit, Michigan
I think Intercooler throw you out of ST. In SP as long as you don't need to modify anything to allow the intercooler to be installed it should be ok.
As far as wheels goes there are essentially nothing that limits you to run whatever in SP. You can also cut fenders to fit. Remember though this is a class designed to run Hoosiers./R-Comps.
burglar
Matt
Troy, Mi
Civic
yep, the STclassing is all Fked right now.
STH you CAN change the intercooler but not in STU...
plus if the DP it catless yeah that takes you out of stu as well
Catless downpipe might be fine, with some caveats:
E. Any catalytic converters are allowed. Catalytic converters must attach
within 6” (152.4 mm) of the original unit. Multiple catalytic converters
may be replaced by a single unit. The inlet of the single replacement
converter may be located no further downstream than 6” (152.4 mm)
along the piping flow path from the original exit of the final OE converter.
Since this is a DD/toy rather than an all out autocross build, sounds like OP would best fit in a local "TSM / Street Tire Street Mod" type class if that's offered by the local club.
phillystyle17_si
phillystyle17_si
Romeo
Philadelphia
It is catless and i do daily it. I'm not trying to go crazy with the wheel size but looking for something close to factory specs in 19in or 18in so i can have more tire then the stock 20in
