mecheng32
1. Remove the negative terminal from your battery.
2. You’ll need a T30 torx screwdriver, an m10 Allen key, a Phillips head and flathead screwdrivers.
3. On each side of the steering column, you’ll find 1 torx bolt that need to be removed.
4. Now that the bolts are removed, the airbag console can be accessed. Make sure you don’t pull it too far out as the wires are still connected to the airbag. You just need to pull it out enough to access the connectors.
5. There are three connectors on the back of the airbag: green, grey, ground. The green and grey are removed by pulling the white tabs up. I’ve circled them for reference. The ground wire may need a flathead screwdriver to provide leverage to remove as it was somewhat difficult to fit my fingers in there.
6. Once these three connectors are disconnected, pull the airbag out and set aside
7. Place your m10 Allen key in the center bolt and remove. It will feel very hard to remove because of the loctite but keep in mind it’s just a long bolt and takes some time to remove (3 min).
8. You also want to remove the plug in connector that is directly above the center bolt (pink, black, and blue wires) It has a tab on the bottom.
9. Mark the nurling on the wheel and hub so you can easily match up the position again and have a straight centered steering wheel at the end of install.
10. Gently push on both sides of the steering wheel back and forth and the wheel will come loose off the hub.
11. Once the wheel is off, then starts the task of removing all the trim pieces. I didn’t take pictures of each step as they are pretty straight forward. All I can say is tread carefully because you can easily break the trim pieces if you try to rush or don’t pay attention to detail. The key is to wedge a plastic trim removal tool or a flathead wrapped in paper towel and carefully work your way around the trim pieces/oem button consoles.
12. There are two connectors that connect the wheel mounted buttons. These have tabs in the middle and are removed before removing the buttons.
13. Install trim pieces on new wheel and reverse the steps to reinstall the wheel.
Hope this helps.
Cheers!
Hope this helps.
Cheers!
