Type R brakes on Si?
Doublestack00
GA
2020 Boost Blue Type R
Anyone made an attempt to do this? Or is there a way to adapter the Brembos?
Now that I am running the R wheels my calipers looks so tiny, I'd love to find a way to run the R brakes. I've seen some guys on the forum with an EX run an older Acura Brembos but they will not work with the larger Si brakes.
I can’t say yay or nay regarding the R calipers, but I have a Brembo setup from @Performance Brakes LTD. The rotors are 12.6”. You can get larger two piece rotors but the price goes way up. The kit I have sells for about $1,000.
Honda Civic 10th gen Type R brakes on Si? F3F2A3B2-94AF-4246-B7FA-D239CD173DDB
WOPSiWOT
South Carolina
2017 Civic Si Sedan
You can get a Brembo BBK for the Si from @Performance Brakes LTD
Doublestack00
Doublestack00
GA
$1000+ is way more than I was looking to spend.
I can get type R calipers with pads for less than $250 each.
You’d be a pretty popular guy if you purchase a set and figure out how to use them. :thumbsup:
Matthyahuw
Matthew
Valley of the Sun AZ
2018 Agean Blue Civic Si Sedan 2016 Omaha Orange Jeep Renegade Trailhawk
S2000 rotors and old JDM 2002-2006 Honda Integra Type R DC5 Brembos fit.
Still not super cheap tho
Wouldn't the different bolt pattern of the R make the rotors useless for a Si?
Chances are that even if the bolt pattern was correct, the rotor offset wouldn't be. The trick is finding a set that lines up correctly.
MavicTB
Terry
Dallas
18 Civic Si Sedan Aegean Blue
This could require thousands of dollars in parts... The rotors are not the same bolt pattern therefore many other parts would be needed to make them work on an Si.
  • Sad
Reactions: AVR
Syntek
Los Angeles, CA
2019 PWP Civic Si Sedan
Gonna bump the shit out of this. But did performance brakes ltdgo out of business?
They sell through Two Step Performance now.
Brembo kit is no longer available from what I understand.
Syntek
Los Angeles, CA
Well, fuck. The search continues then hahs
