Alec1995x
- Alec
- Jun 27, 2020
- 5
- 2
- United Kingdom
- 2019 FK8
Hello all!
EDIT: NEVERMIND! I FOUND THE AMPLIFIER UNDER THE PASSENGER CAR SEAT. https://www.civicx.com/forum/threads/type-r-2019-fk8-stereo-wiring.51236/post-1135395
I have been doing my research into adding an amplifier & Sub to my FK8. I have all the necessary parts and tools to carry this project. Just to clarify, I have the FK8 UK/EU version, there is no subwoofer in the truck hence why I have to tap the wires in the head unit.
I was following this post to connect the speaker outputs wires to my LOC but I ran into some really weird problems. The diagram doesn't match the one posted and I cannot find one that matches anywhere! https://www.civicx.com/forum/threads/headunit-wire-diagram.2886/
I have taken photos (see below!) of my version of the 24 pin connector below, as you can see the numbers of the pins are different (12,24 on the left side, 1,3 on the right side) compared to the diagram. The more confusing is actually the number of wires total on this connector... There are only 9 wires including the black & brown wire (+12V & ground). I cannot work out how this is possible considering I have an 11 speaker system. I also have taken a look at other connectors but doesn't seem to be stereo speaker outputs.
Really stuck right now have all the parts required but cannot connect it all together.
Would really appreciate it if anyone can provide me with some guidance! Thank you!
24pin connector at back of my head unit
24 pin connector plugs into the highlighted slot
Serial of the head unit.
Some other connector (doesn't seem to be stereo outputs)
Thank you!
Regards,
Alec
Thank you!
Regards,
Alec
