knadsady
- Jun 24, 2018
- 14
- 57
- 5
- Ohio
- 2018 Civic Si Sedan
Up for sale is a pair of resistors used for eliminating hyperflash when using LED bulbs in the turn signals.
These high-quality resistors were made by Jeff@DIYCarModz and are plug-n-play with factory wiring (these use OEM Honda plugs as seen in the attached pics for a super easy install).
These allow you to run LED bulbs (I recommend TypeRLEDs dot com, a little pricey but VERY bright and high quality, video attached) in both the front AND rear turn signals with zero hyperflash. Installation is extremely simple as these resistors only need to be installed for the front turn signals even though they eliminate hyperflash for the rear turn signals as well.
Installation: remove OEM front turn signal bulb from housing, unplug it from factory wiring, insert resistor into same factory wiring plug, insert new LED bulb in the remaining resistor pass-thru plug, insert new LED bulb back into housing, repeat for other side.
For my setup, I was running LED bulbs in the headlights, taillights, fogs, and all turn signals and had no hyperflashing anywhere.
NOTE: you will need 3M double-sided adhesive and zip ties for installation (NOT included)
Price is $OLD firm shipped and PayPal'd
